Needed!
Old Dec 3, 2006 | 09:44 AM
InNeedOfAnEG's Avatar
Default Needed!
I was driving hom the other day and heard my pass. side rear scraping. I went to a friends, jacked the car up, tired to rotate the rear wheel and it would hardly move.....i'm assuming my rear caliper is stuck because the pads were rubbing the rotor w/o ebrake up. also, the rear wheel was hot as hell! Post whatcha got! Thanks.
Grady
Old Dec 3, 2006 | 10:28 AM
BlueIntegraBoy's Avatar
Default Re: Needed! (InNeedOfAnEG)
Happened to me. I found out it was the return spring for the ebrake cable. Whenever I pulled the ebrake cable up then release it, the caliper didn't fully disengage.
Old Dec 3, 2006 | 10:39 AM
JDM_DC4_Fanatic's Avatar
see if the piston will rotate back into the caliper assembly easily, you may also have a seized piston. Also, inspect the piston boot, make sure no dirt or any debris got into the cylinder.
jokerstone
Jan 6, 2015 08:16 PM
90lsvcrxva
Suspension & Brakes
Jul 29, 2012 11:59 AM
sleepystyle
Jan 11, 2006 01:15 PM
SloCivicHMM
Nov 6, 2003 09:38 AM
DA-MAX
Jun 24, 2003 10:52 AM
