b16 timing issue Help?
Old Dec 4, 2006 | 12:20 PM
integg93's Avatar
Default b16 timing issue Help?
I need some help fellas i have a b16 with adjustible camgears car ran good but it started leaking coolant from water pump so i decide to change the water pump. put every thing back alined all the points now car wont start it starts stays on for a while but it sounds like its boggin then i just turn it off checked spark plugs & spark plugs are filled with oil. could this mean that timing is really messt up maybe different issue?? Thanks AHead
Old Dec 4, 2006 | 05:15 PM
JasonST's Avatar
Default Re: b16 timing issue Help? (integg93)
Oil in the spark plugs shouldn't be timing related. Is it dripping down ur plugs or actually soaked all inside ur cylinders? Likely it's ur spark tube seals, they're little rubber gaskets that are on the bottom of ur valve cover to keep oil out, maybe when u put the valve cover back on one or more fell off. If they are there then ] try and replace them, it's really cheep and the usual fix for this problem.
busta7777
Mar 6, 2011 04:04 AM
alupso
15
May 2, 2006 01:49 PM
Mr.Speed
10
Jun 18, 2005 06:15 PM
Bigjon
32
Jul 19, 2003 07:36 AM
Fooman
Jan 14, 2002 05:57 PM
