94 integra electrical starting problem
Old Dec 3, 2006 | 11:45 AM
dschultz226's Avatar
Default 94 integra electrical starting problem
ok i have a 94 integra ls everything is stock on it, well it starts and runs but dies right after you let go of starting it, all power is then lost, no dash lights, no windows ect, but if you turn the key back to the start position everything works fine and it starts again but right after you let go of the key everything dies again, so basically it only runs if you hold the key in the start position, i checked all the fuses on it, can anyone help,
Old Dec 3, 2006 | 11:47 AM
JDM_DC4_Fanatic's Avatar
Default Re: 94 integra electrical starting problem (dschultz226)
check the main relay, sounds like ECU or massive wiring problem...better get out the multi-meter and get busy
Old Dec 3, 2006 | 11:54 AM
i already check the main relay it tested out fine
Old Dec 3, 2006 | 12:16 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
What about the key switch itself ?
Old Dec 3, 2006 | 12:22 PM
Default Re: 94 integra electrical starting problem (wrx-killer-Sti eater)
well i took all that apart to and it tested odd, like i was saying the inside of the car only seems to have power when its in the start position but once it goes back to the run it looses all power but the switch works fine, man i am really confused about this problem
Old Dec 5, 2006 | 09:22 AM
got it fixed last night, it turned out to be the electrical part of the ignition switch in case anyone was wondering cost 47$ brand new from the dealer
92 civic ex 4dr
Feb 14, 2015 09:09 AM
carlossolorzano
Jun 1, 2012 08:03 PM
mrdeadman
Mar 6, 2012 08:27 PM
skazoo
Jul 11, 2009 12:09 PM
exies
Jul 12, 2006 05:15 AM
