Build-up on inside of window
Old Dec 5, 2006 | 11:46 AM
silentdeath12886's Avatar
Default Build-up on inside of window
When i got my car from a used car dealership there was a small chip in the frotn windshield so they had it replaced. i never had any problems with it except the outside molding (the thinner part that touches the glass) comes loose or jsut bulges out a little and i push it back in. anyways recently i discovered that there is some kind of build-up of on the inside of the glass. it started on the bottom and the sides like when you wash your car and you see water marks except the watermarks are going up the windshield and towards the center from the sides. then the top start to dot he same thing working its way down...is it a bad seal? time to replace the whole molding maybe?
Old Dec 5, 2006 | 11:59 AM
Perfectionist's Avatar
Default Re: Build-up on inside of window (silentdeath12886)
It's not clear what you're describing. By inside, do you mean between the glass layers? (It's laminated. Glass, plastic, and glass.) If so, bad windshield or installation.
Old Dec 5, 2006 | 12:16 PM
its the inside inside glass part. there isnt any water build-up just the water marks of some sort. im assuming its bad install and guess ill buy new moldings and have it put in. where can i find all the necessary parts?
Obese
Apr 24, 2010 05:50 AM
mnmsddy
Dec 18, 2009 01:41 PM
lucky13AP2
Honda S2000
13
Jun 28, 2006 06:39 PM
LoganMantits
Jun 10, 2005 12:01 PM
HatchBox
Jan 15, 2003 07:53 PM
