Mis-shift question
Old Dec 3, 2006 | 10:36 AM
jamjam's Avatar
Default Mis-shift question
Hey guys, I know this sounds noobish but I recent mis-shifted in a race. I have a gsr motor w/ intake, headers, exhaust, skunk2 manifold, and skunk2 ecu. I freken mis-shifted 4th gear and hit either 95k or 9k.....
Anyways, the car is still running, no smoke whatsoever. To me, it feels as though as the car is a bit laggy because its the first time I missed a gear that hard but to others, they say its running fine.
Am I just paranoid? What could be the possible damage?
If it is a bent valve, would it be hard to check if it is?
Old Dec 3, 2006 | 10:44 AM
carrnut21's Avatar
I'm not an expert in these matters, but you probably should have a compression test done.
Old Dec 3, 2006 | 11:34 AM
IntegrasAreBest's Avatar
yup get a compression test.
Old Dec 3, 2006 | 12:34 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Mis-shift question (jamjam)
If you bent exhaust valves, the engine would not idle well and would havbe reduced low-end power. The compression test will provide a definte answer.
Old Dec 3, 2006 | 11:19 PM
jamjam's Avatar
thanks for the input guys... my car idles like it is suppose to. For sure ill do a compression test. What do you guys think could be the problem? Fried a piston ring?
Also, an off-topic question, do you think skunk2 procam1's are good for boost?
Old Dec 3, 2006 | 11:36 PM
__oversea's Avatar
if things go bad, bent valves.
Old Dec 4, 2006 | 02:33 AM
1DA2NV's Avatar
its prolly just you man, you had to do much worse than that to bend valves and cause damage to the engine, it wouldn'y hurt to do a compression test but i doubt that you did any thing to cause any kind of bad thing to happen since the motors on our cars have REV limiters on them for that purpose, to keep you from doing damage to internals, you never know though, go with your gut i guess
Old Dec 4, 2006 | 06:29 AM
gsrclan's Avatar
Shouldn't the engine cuts off when reve limt is exceeded?
Old Dec 4, 2006 | 08:01 AM
MATiC's Avatar
u can never be too sure.
i missed a shift going from 3rd to 4th in my LS, accidently slammed it into second..
not good.. my engine rev'ed to hell for maybe a split second..
i thought all was good. maybe a month later, new motor was needed.
Old Dec 4, 2006 | 08:08 AM
jamjam's Avatar
the thing is I have the skunk2 ecu, so I have no limiter. It revs freely but I'm not suppose to hit like 9500 or 10k or even anything above 8500. Is it hard to check if you have bent valves? What could be another reason?
Old Dec 4, 2006 | 08:17 AM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamjam &raquo;</TD></TR><TR><TD CLASS="quote">Also, an off-topic question, do you think skunk2 procam1's are good for boost?</TD></TR></TABLE>
no. oem itr/ctr's work great with boost however.
Old Dec 4, 2006 | 11:42 AM
RedB20DA's Avatar
Default Re: Mis-shift question (that one doood)
you should really look into an ECU with rev limiter,everyone misses a gear sometime.DO a compression test but i belive youll be ok.
ge_itr
Aug 13, 2006 08:14 AM
DC5 Demon
Jan 17, 2006 10:50 AM
Sport_Injected
Aug 25, 2004 09:21 PM
IRFertl
May 22, 2004 07:19 AM
