headlight question
Old Dec 4, 2006 | 07:16 PM
hks369's Avatar
Default headlight question
i have a 97 ls my headlights are really fogged up and one has water in it.... how do i clean those and is there a way i could just get the outer plastic part and just put them on or clean them to look clear again
Old Dec 4, 2006 | 08:08 PM
hks369's Avatar
Default Re: headlight question (hks369)
bump
Old Dec 4, 2006 | 08:54 PM
IgnitionZ05's Avatar
you can clean the exterior of the headlight using some meguires scratch x, removes oxidation on the headlight works really good
Old Dec 4, 2006 | 08:57 PM
RA429's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IgnitionZ05 &raquo;</TD></TR><TR><TD CLASS="quote">you can clean the exterior of the headlight using some meguires scratch x, removes oxidation on the headlight works really good </TD></TR></TABLE>
worked for me!
Old Dec 4, 2006 | 09:41 PM
bg-33p's Avatar
Default Re: headlight question (ngswimmer08)
There's been many DIY threads on how to make em nice and shiney, since i saw and bookmarked this one today ill share http://forums.clubrsx.com/showthread.php?t=434436
Old Dec 4, 2006 | 11:16 PM
TurboGS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hks369 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 97 ls my headlights are really fogged up and one has water in it.... how do i clean those and is there a way i could just get the outer plastic part and just put them on or clean them to look clear again</TD></TR></TABLE>
I have the same problem, so I took the headlight off and pulled the bulbs out. Then I poured the water out and put a hair dryer to it for 30 minutes in both "holes" . Since it condensed back up, I plan to take it off again and hold it under water to find the leak, then silicone the leak up. I hope this works.
Old Dec 4, 2006 | 11:30 PM
alexisthemovie's Avatar
this happens after every time i wash my car. annoying as hell. also i have heard good things about meguiars scratch x.
i used turtle wax scratch and swirl remover on parts of my car and it sucks.
Old Dec 5, 2006 | 08:49 AM
bshshondaman06's Avatar
Default Re: (alexisthemovie)
i use megiuers mag and aluminum wheel polish on my headlights and other plastics. its amazing and restores them to new.
Old Dec 5, 2006 | 02:42 PM
hks369's Avatar
what about plast-x?
Old Dec 5, 2006 | 07:09 PM
JDM As It Gets's Avatar
search ; theres a write up on how to clean hazed / foggy headlights. they even show u how to crack em open and clean em and make them like new and re-seal them w/o causing moisture lock and problems in the future
Old Dec 5, 2006 | 07:39 PM
hks369's Avatar
thanks!
Old Dec 5, 2006 | 08:47 PM
aaronISthrowed's Avatar
I used Scrach Off (i think thats the name) and it works real well.
edit: its called Scrach out
peAches yO
Lighting
Jun 9, 2011 03:33 PM
sonnyleq
May 23, 2008 06:15 AM
dc2long
Mar 30, 2007 02:58 AM
Ronin Integra8
Jan 27, 2003 10:08 AM
