Time to replace the clutch
Old Dec 3, 2006 | 12:03 AM
97RSTEG's Avatar
Default Time to replace the clutch
how hard is it to change the clutch on a 97 RS Integra
Old Dec 3, 2006 | 12:08 AM
()()DC2's Avatar
hard...
Old Dec 3, 2006 | 12:24 AM
__oversea's Avatar
Default Re: (()()DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ()()DC2 &raquo;</TD></TR><TR><TD CLASS="quote">hard...</TD></TR></TABLE>
some what. and take long time. lots of bolts to deal with.
Old Dec 3, 2006 | 12:35 AM
97RSTEG's Avatar
Default Re: (FourMotion)
do you have drop the whole engine or can you just drop the tranny?
Old Dec 3, 2006 | 12:45 AM
sdr KEL's Avatar
you dont need to drop the whole engine... take out the motor mount on the tranny... and theres about 7-8 bolts..
Old Dec 3, 2006 | 06:03 AM
9311dan's Avatar
take off the wheel
disconnect brake caliper
turn rotor assembly
pop out axle
disconnect trans mounts
take off about....i dunno 16 tranny case bolts
disconnect reverse switch
do what you want with the starter, i replaced that at the same time as my clutch/pp/flywheel
trans should drop out easily and fluid will go everywhere
take off PP bolts and clutch is right behind it, then the flywheel.
re-assemble.
Old Dec 3, 2006 | 08:32 AM
black92DA's Avatar
Default Re: (9311dan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9311dan &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE> make sure to drain the tranny first
Old Dec 3, 2006 | 08:48 AM
lVlemphizStylez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9311dan &raquo;</TD></TR><TR><TD CLASS="quote">take off the wheel
turn rotor assembly
pop out axle
re-assemble.</TD></TR></TABLE>
fluid go everywhere??? umm have you ever removed a transmission dude?? The spline that connects the engine to the bell housing has no fluid in it...The fluid is contained INSIDE the tranny case with the gears themselves, not with the spline..The only thing between the engine and spline is some like assembly lube...And removing the brake calipers is completely UNECCESSARY...
Modified by lVlemphizStylez at 10:08 AM 12/3/2006
Old Dec 3, 2006 | 08:56 AM
PrinceAli132's Avatar
Default Re: Time to replace the clutch (97RSTEG)
Its not that hard. Make sure you have a helms, all the right tools (if you have access to an impact wrench then it will make it all the easier), and a friend to help lower and put back the tranny. Also, make sure to torque everything bck to spec.
Ali
Old Dec 3, 2006 | 08:58 AM
turn rotor assembly
pop out axle
I agree with lVlemphizStylez, a few of the steps you mentioned aren't necessary and fluid will not spill everywhere if you drain the tranny.
Alsp, don't forget to get new crush washers for the drain plug.
Ali
Old Dec 3, 2006 | 10:25 AM
JDM_DC4_Fanatic's Avatar
the only place where you may have fluid coming out from, is the axel holes. However, the gear should of been drained Prior to removal...work clean, and you'll work happier
Old Dec 3, 2006 | 08:34 PM
9311dan's Avatar
the reason fluid went everywhere is b/c it was my first time doing it and i haven't done it since....it was during an AT-MT conversion, so I did take the AT trans off, and yeah...fluid, a lot of fluid.
Old Dec 4, 2006 | 11:17 AM
97RSTEG's Avatar
Can you guys make any good recommendations for clutch kits? I plan boosting later, but not whole lot
Old Dec 4, 2006 | 02:41 PM
9311dan's Avatar
I have the Clutchmasters Stg 1 Clutch and PP, as well as the Clutchmasters Aluminum 8 lb Flywheel...it's a nice combo.
Clutch and PP-$450
Flywheel-$240
Old Dec 4, 2006 | 02:48 PM
Rooftop voter's Avatar
Man,I got to change my clutch too. I'm not looking foward to it.
Old Dec 4, 2006 | 02:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9311dan &raquo;</TD></TR><TR><TD CLASS="quote">the reason fluid went everywhere is b/c it was my first time doing it and i haven't done it since....it was during an AT-MT conversion, so I did take the AT trans off, and yeah...fluid, a lot of fluid.
Even in an auto tranny, there is no fluid in the input shaft. likewise, the only way that would would have fluid spilling everywhere in an AT is out of the axel seals, drain plug, or if you droped the torque converter like a dumbass.
Old Dec 4, 2006 | 05:33 PM
JmurGSR98's Avatar
Default Re: (97RSTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RSTEG &raquo;</TD></TR><TR><TD CLASS="quote">Can you guys make any good recommendations for clutch kits? I plan boosting later, but not whole lot</TD></TR></TABLE>
I'm using an Exedy Stage 1 clutch kit and 9 lbs flywheel running 5 psi. Holding up really good and feels like stock clutch.
Old Dec 4, 2006 | 07:48 PM
__oversea's Avatar
Default Re: (JmurGSR98)
for boost, ACT stage2 will hold up very nice.
m1northreat
Honda S2000
18
Jan 5, 2008 09:25 AM
veritasaequatis
Jan 22, 2007 08:33 PM
h8ted ek
Dec 20, 2006 06:02 AM
citrus3000psi
Feb 10, 2006 08:49 AM
flip1199
Nov 7, 2005 11:07 AM
