Dent on integra, checking options.
Old Dec 5, 2006 | 11:14 AM
Typeron's Avatar
Default Dent on integra, checking options.
Ok so I got this dent on my integra near the hatch , above the passenger side rear tire. Took it to a body shop and got an estimate of $350 to repair it, said he'll push it out and fix it up with bondo and then repaint it. Seemed a little high and was seeing if that was an ok price. Or if there was other options or just check another shop. Thanks
Old Dec 5, 2006 | 11:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Sounds pretty reasonable if he can make it look good, because he's going to have to paint the entire quarter panel and blend it up into the C-pillar and into the doors. Good luck with that for only $350.
Old Dec 5, 2006 | 11:53 AM
b20acura's Avatar
Default Re: (PatrickGSR94)
for 350 make sure he does a good job. majority of that money imo is really just the painting
Old Dec 5, 2006 | 12:22 PM
97itypeR's Avatar
just paint the scratch the same color as the body and itll be fine, since its a light color, ull hardly see it.
my silver GS has about 3 dents, small but the paint didnt come off so u can only see if when ur up super close/.
Old Dec 5, 2006 | 12:58 PM
Sam92Teg's Avatar
Default Re: Dent on integra, checking options. (Typeron)
Do you plan on painting your car in the near future? If so, use some scratch touch-up paint to prevent rust and wait till then. It is much cheaper at body shops when all the problems are fixed at once instead of piece meal work.
Old Dec 5, 2006 | 01:01 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds pretty reasonable if he can make it look good, because he's going to have to paint the entire quarter panel and blend it up into the C-pillar and into the doors. Good luck with that for only $350.</TD></TR></TABLE>
I agree. That actually sounds low to me for the amount of work involved. I'd be slightly concerned about the final results, but then, I'm rather picky about bodywork.
Old Dec 5, 2006 | 07:08 PM
JDM As It Gets's Avatar
350$ is nothing..
Old Dec 6, 2006 | 05:06 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (JDM As It Gets)
yeha if its a reputable place, $350 is a drop in the bucket. post pics when hes done
Old Dec 6, 2006 | 06:10 AM
Yemdogg's Avatar
Default Re: (SupersonicBlueGSR)
$350? you can buy an intake for that much..
Old Dec 6, 2006 | 06:23 AM
aaronISthrowed's Avatar
Default Re: (Yemdogg)
350 is pretty cheap, i say do it.
shockerjoe says
Appearance Build Threads
74
Sep 24, 2015 08:09 PM
LShatchboy
15
Aug 29, 2006 04:41 PM
cilvia
Mar 17, 2006 04:45 PM
The_Nomad
May 6, 2005 08:58 AM
Bay_707
Aug 7, 2004 07:28 PM
