Integra steering is Off...
Old Jun 28, 2007 | 07:43 PM
BoltonGSR's Avatar
Default Integra steering is Off...
I did a B20 swap on my 96 integra and ever since my car seems to ride much rougher..
The car sat for a year before the swap...
1. It hits harder over bumps
2. Steering seems lazy
3. I sometimes hear a loud CRASH when i hit bumps fast enough
4. The steering doesnt feel as tossable as it used to...
Ive already check ALL of the suspension and unless i overlooked something i cant figure it out... I flushed the fluid in the power steering too...
I know it cant be the B20 weight can it? Isnt the B20 identical in weight to a B18?
Old Jun 28, 2007 | 07:53 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Integra steering is Off... (BoltonGSR)
did you unseat the ball joints with a pickle fork?
Old Jun 28, 2007 | 08:24 PM
BoltonGSR's Avatar
Default Re: Integra steering is Off... (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
did you unseat the ball joints with a pickle fork?</TD></TR></TABLE>I dont think so.... what in the world does that mean?
Old Jun 28, 2007 | 08:31 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR &raquo;</TD></TR><TR><TD CLASS="quote">I dont think so.... what in the world does that mean? </TD></TR></TABLE>
well when you took apart the suspension to put the motor in, if you used a pickle fork on the ball joints, it will ruin them.
Also, is the car lowered? Lowered cars put a lot of stress on the upper ball joint due to the camber angle. They will fail from time to time and make all sorts of noise.
How did you check everything in the suspension?
Old Jun 28, 2007 | 08:39 PM
numbnuts22715's Avatar
are all of the bushings in good condition?
sometimes leaving them sitting for years can cause siome damage.
Also, how much of the suspension did you take apart to install the engine? You may be needing an alignment.
Old Jun 28, 2007 | 09:28 PM
BoltonGSR's Avatar
Default Re: (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">are all of the bushings in good condition?
Also, how much of the suspension did you take apart to install the engine? You may be needing an alignment.</TD></TR></TABLE>I just took out the forks, tie rods, and let the hub hang... I havent aligned it yet.... I guess i should to see if that will help..
Old Jun 29, 2007 | 02:05 AM
OC Geezer's Avatar
Default Re: (BoltonGSR)
Try aligning it first.
tsunami77
Apr 20, 2008 01:30 PM
Jay J
May 4, 2006 10:25 PM
O RLY
May 3, 2005 06:00 PM
MAD ITR 55
Honda S2000
Aug 15, 2004 03:29 PM
