94 Integra...need help!
Old Jul 2, 2007 | 01:28 PM
Cooker4418's Avatar
Default 94 Integra...need help!
I had this problem last year...stopped using my car for the winter and now its doing it again. I bought a new starter,new distibutor, and a new battery last year. I jumped it and it ran for a few minutes. I turned it off and came back a hour later and it wont start again. It tries to start and makes a chugging noise and then there's a clicking noise down by the fuse box. Im not sure what it is so if you could help let me know. Thanks
Old Jul 2, 2007 | 01:31 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: 94 Integra...need help! (Cooker4418)
Is it still turning over? or is it not turning over at all just clicking? Does it turn over real slow, like not slow enough to start it? If its just clicking it probably just needs a jump and your alternator should be able to keep it charged if you drive around for 5-10 minutes. If its not that go to the next easiest thing check your starter.
Old Jul 2, 2007 | 03:25 PM
sdinteg's Avatar
Sounds like it could be a battery or grounding issue. If a car battery sits in a discharged state for too long, it will lose its ability to hold a charge. Try jumpstarting the car - if it starts right up, it's most likely the battery.
Old Jul 2, 2007 | 03:42 PM
Dartanian's Avatar
Check the battery cable connections. A loose connection will cause exactly what you are describing.
euroborn1
21
Aug 15, 2008 11:46 AM
Legendaryyaj
Mar 8, 2007 01:41 PM
JDM Approved
16
Dec 4, 2006 05:39 AM
CBS2000
Honda S2000
11
Apr 13, 2006 03:58 PM
NMElude97
Jan 30, 2004 01:50 PM
