Timing Belt Keeps Hitting T-Belt Cover
Old 06-29-2007, 10:49 AM
DVPTeG's Avatar
Default Timing Belt Keeps Hitting T-Belt Cover
I have a 2000 Gs-R. Pretty much stock except I/H/E and S2 IM.
My timing belt is hitting the timing belt cover. It makes a "slapping" noise and it's loud. It happened about a month ago and fixed it.
What could be causing it do this AGAIN?? Should I get a new T-belt?
Old 06-29-2007, 10:59 AM
Force1stiptopped's Avatar
how many miles on the car?, if there is a lot, change the timing belt and the tensioner
Old 06-29-2007, 11:01 AM
Daisy... Daisy...
Dogginator's Avatar
Default Re: Timing Belt Keeps Hitting T-Belt Cover (DVPTeG)
The tensioner bolt is probably loose.
Old 06-29-2007, 11:36 AM
np98's Avatar
I third that, tensioner.
Old 06-30-2007, 09:31 AM
touintegra's Avatar
Did you diy, meaning change the timing belt.....or shop. well check to see if your missing the spacers that spaces the timing belt pulley from the block and the other between the timing pulley and the crank pulley.......something like this......[block]IOIQ
[block] = your block
I = spacer
O = timing pulley
Q = crank pulley
ThA IntegrA HI
12-17-2009 06:37 PM
chromeBuddha
08-04-2008 12:43 PM
PrecisionH23a
08-14-2002 09:22 AM
PrecisionH23a
08-14-2002 05:16 AM
Quick Reply: Timing Belt Keeps Hitting T-Belt Cover
