LS Vtec
Old Jul 6, 2007 | 05:03 PM
Coreyg's Avatar
Default LS Vtec
Well i'm interested in getting a gsr but im not sure if im giong to be able to find one for a cheaper price where i live. And i was wondering what kinda cash are we looking at with setting up Vtec on an LS? Are ls with vtecs faster than gsr's stock? and how much whp does a lsvtec stock have?
And do you gotta replace any internals? I'm not very educated on this stuff.
Old Jul 6, 2007 | 06:01 PM
Coreyg's Avatar
bump
Old Jul 6, 2007 | 06:43 PM
posHonda's Avatar
if youre not very educated in this stuff than an ls/vtec is not for you no offense.
save up for the gsr
Old Jul 6, 2007 | 06:54 PM
PLAGUED_DB7's Avatar
Default Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">if youre not very educated in this stuff than an ls/vtec is not for you no offense.
save up for the gsr</TD></TR></TABLE>
Not so...Just go to a good shop...Give them your money, and BAM LS/VTEC!
Old Jul 6, 2007 | 06:57 PM
Coreyg's Avatar
my brother is a car mechanic and works at a dealership shop. I'm just curious of what kinda power will be the outcome and how much itll set me back?
Old Jul 6, 2007 | 07:09 PM
Sumslapper's Avatar
Year 3030
Default Re: (Coreyg)
both have great potential but will require lots of money. like stated previously, if your not well educated in the field of frankenstein motors skip it. They are a lot of work to keep running properly and would probably result in leaks and headaches if not PERFECTLY and PROPERLY assembled. Stick with the gsr.
Old Jul 6, 2007 | 07:15 PM
Doostur's Avatar
Search... people have been in the same situation as you a million times.
Old Jul 6, 2007 | 07:17 PM
posHonda's Avatar
Default Re: (PLAGUED_DB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUED_DB7 &raquo;</TD></TR><TR><TD CLASS="quote">
Not so...Just go to a good shop...Give them your money, and BAM LS/VTEC! </TD></TR></TABLE>
even many shops dont do it right and the best shops will cost an arm and a leg.
depending on how the ls/vtec setup is built, it could perform similar to a stock gsr or it could blow ***** off of one. if you dont plan to put much money into the build than dont expect it to destroy a perfectly running gsr.
Old Jul 6, 2007 | 07:18 PM
Doostur's Avatar
Buy an LS ... boost it at 8 pounds and call it a day.
Old Jul 6, 2007 | 08:46 PM
depending on how the ls/vtec setup is built, it could perform similar to a stock gsr or it could blow ***** off of one. if you dont plan to put much money into the build than dont expect it to destroy a perfectly running gsr.</TD></TR></TABLE>
Which brings up the obvious...
"You get what you pay for"
Old Jul 6, 2007 | 09:32 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
If you decide to go lsv, put some itr pistons and some ctr cams. and if you dont wanna do that then just buy a gsr.
CR3X
Oct 26, 2007 05:43 PM
CivicK20
Oct 29, 2006 01:47 PM
crixer340
Aug 14, 2006 04:01 PM
JDM-Rota
Aug 5, 2005 08:35 PM
Edgemingsr
May 1, 2004 06:05 PM
