fuel pump problem
Old Jul 6, 2007 | 09:05 AM
GSR-TRBO-DA's Avatar
Default fuel pump problem
so this is my situation fuel pump does not prime. i've changed the fuel pump and the main relay.still nothing i still don't hear the main relay click when you put the key in the ingnition. i'm checking for fuel on the fuel filter. is there a fuel relay because i've looked on the fuse box in the engine compartment and the kicker panel on the driverside and have checked the haynes manual. and it doesn't say anything about a fuel relay, or a fuse that has to do anything with fuel.
p.s. the haynes manual doesn't even say anything about a main relay.so i'm thinking its not going to say anything about a fuel relay or fuse. what could cause the main relay not to get power? car does not have alarm or killswitch to my knowledge.
Old Jul 6, 2007 | 01:29 PM
Default Re: fuel pump problem (GSR-TRBO-DA)
it was the ecu
Scarekrow
Oct 11, 2015 08:05 PM
toddkeeb
Aug 5, 2013 02:11 PM
EGKREW
Nov 26, 2008 11:54 AM
gsrt nick
Oct 23, 2006 06:43 PM
Agent Daimon
Feb 9, 2003 01:06 PM
