fuel filter help
Old Jul 4, 2007 | 06:31 AM
honcrx91si's Avatar
Default fuel filter help
i have a 94 gsr and i cant get the fuel filter off. on the top of the filter i can take out the small bolt that goes down through the other bolt and fuel line, but after i get that off i cant get the next bigger bolt on the top off, is that suppose to come off or just pull out.
Old Jul 4, 2007 | 06:59 AM
c1civic's Avatar
tried doing mine the other day, i was struggling to and ran out of time, bump for some help
Old Jul 4, 2007 | 08:55 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: fuel filter help (honcrx91si)
The small bolt is only for attachment of a fuel pressure regulator. You need to remove the larger banjo bolt. Use a 6-point socket. Use a line wrench for the connection on the bottom of the filter so that you do not strip it..
Here is a diagram:
Old Jul 4, 2007 | 01:47 PM
len's Avatar
len
Default Re: fuel filter help (Dogginator)
Dogginator is correct, just loosen the top banjo bolt along with the nut for the line from the bottom, then remove the filter assembly by unbolting the mounting bracket from the firewall.
k3ntegra
Aug 28, 2014 05:50 PM
MelJ
10
Mar 20, 2011 05:26 PM
Archxor
Nov 7, 2006 04:36 PM
cvc323
Jun 29, 2003 11:09 PM
LiZaRDz CiViC Si
Mar 19, 2003 09:17 AM
