temps and starting problem
car turns but doesnt start..so i hold the gas peddle down then it starts up..release gas peddle..but idles low for a couple of seconds on start up..
Another problem is my temps mostly stays normal but occasionaly it will go 1/4 of the way to the H...then back to normal temp as i drive
Temp thing may be your thermostat going out or acting out... I had the same problem and fixed it with a new thermostat.
The starting problem may be your main relay or fuel pump (probably not getting enough fuel to initially start)...
thanks for the replies..also my fans were not working also..but i took the car in to find out the head gasket was blown
so now i got to raise up the cash to fix
Asmooh
18
Apr 15, 2014 07:05 AM
