need help
Old Apr 6, 2008 | 04:35 PM
dc2much's Avatar
Default need help
ok my speed sensor went out. replaced it and it still dont work. it has 12 volts going to it. but the signal wire is reading 9.27 volts. as far as i know it is supposed to be around 5 volts. also it doesnt pulse between 0-5 at all when i spin the wheel. anyone know what the problem could be? any help or anything i could check. also it is a 94 gsr and the check engine light comes on for the vss.
Old Apr 7, 2008 | 01:44 PM
dc2much's Avatar
Default Re: need help (dc2much)
ok i checked the signal wire again but this time i took the speedometer out and the volts dropped to 4.88 but the sensor still doesnt pulse from 0-5-0-5-0. any thoughts?
Old Apr 7, 2008 | 03:58 PM
90Rexx's Avatar
you ahve a short to power somewhere. your speed sensor should read 0 volts when theres no movement. as you move the wheel the sensor should pick up movement and increase voltage.
crackers
Jul 25, 2015 07:41 PM
2.2litrebeater
Apr 28, 2007 09:40 AM
98IntegraLSNonVtec
Dec 24, 2005 11:52 AM
Silvabullet
Jan 5, 2005 02:06 AM
worrdogg
Sep 28, 2003 12:10 AM
