loud squeek issue
Old Apr 4, 2008 | 06:28 PM
mach0's Avatar
Default loud squeek issue
ok today I hit a pot hole..it was not big but there was a car next to me in the other lane and the lane itself was too damn small to avoid it..anyway now my front pass side wheel( not sure what it is) is squeeking..not a scrape but almost sounds like a squeeky bed..can anyone help me so I can head in the right direction? its only around the streets..on the highway you can't hear it...
Old Apr 4, 2008 | 07:00 PM
90_EX_Civic's Avatar
Default Re: loud squeek issue (mach0)
check your springs yet?
Old Apr 4, 2008 | 09:21 PM
jhammond_82's Avatar
Reject Papi
Default Re: loud squeek issue (90_EX_Civic)
you probably bent something.
Old Apr 5, 2008 | 04:15 AM
mach0's Avatar
the ride is still good and no alignment issues.i will check the springs this afternoon..Thanks
Old Apr 5, 2008 | 04:32 AM
mach0's Avatar
could it be a blown strut? gr-2's are not expensive to replace.
Old Apr 5, 2008 | 05:06 AM
Dogginator's Avatar
Daisy... Daisy...
A blown shock would leak. Can you bounce the car and make it squeak?
Old Apr 5, 2008 | 05:10 AM
mach0's Avatar
Default Re: loud squeek issue (Dogginator)
i did not try to bounce the car yet but when it bounces like over bumps and stuff and squeeks and when i let go of the brake and the hit the gas to take off, as soon as the load shifts you hear the squeek. also, i have a kyb gr-2's and they are gas filled. idk if that makes a diff on leaking. Thanks
Old Apr 5, 2008 | 05:22 AM
Dogginator's Avatar
Daisy... Daisy...
If you can make the squeak by bouncing the car, you may be able to pinpoint the source.
Old Apr 5, 2008 | 05:46 AM
mach0's Avatar
thanks ill check later
Old Apr 7, 2008 | 07:02 AM
mach0's Avatar
checked and its blown..ordered two new fronts..thanks
Boogie9IGN
Suspension & Brakes
Dec 14, 2009 05:53 PM
drunkenboi
May 3, 2005 03:06 PM
acuraLSSE95
Aug 25, 2004 09:22 PM
Gumbey75
Jun 18, 2004 01:54 PM
DOHCon15s
Mar 9, 2004 08:37 AM
