NEED HELP WITH TEG
Old Apr 3, 2008 | 07:20 PM
pearl404's Avatar
Default NEED HELP WITH TEG
I HAVE A 95 LS AND IT SAT FOR A YEAR. THEN I PUT A MOTOR IN IT AND IT STARTS UP FINE RUNS FINE UNTIL YOU DRIVE IT A COUPLE OF MILES, THEN IT STARTS TO SPUTTER AND SMOKES (WHITE) AND SMELLS LIKE RAW GAS, AND IT HAS A LOSS OF POWER. BUT YOU CAN LET IT SIT FOR 10-15 MIN AND ITS FINE UNTIL YOU DRIVE IT AGAIN. JUST WONDERING IF ANYONE HAS HAD THOSE PROBLEMS THAT COULD HELP ME. PLEASE
Old Apr 3, 2008 | 07:24 PM
matthevelli's Avatar
Default Re: NEED HELP WITH TEG (pearl404)
What engine in it? check engine light? condition of wires,plugs, cap, rotor?
Old Apr 3, 2008 | 07:26 PM
pearl404's Avatar
Default Re: NEED HELP WITH TEG (matthevelli)
ITS A B18B1 NO CELS AND ITS ALL NEW MSD
Old Apr 3, 2008 | 07:38 PM
pearl404's Avatar
I KNOW THIS DONT MEAN ANYTHING, BUT I HAVE A NARROW BAND A/F GAUGE AND IT WHEN IT ACTS UP, IT GOES FROM NORMAL TO LEAN, AND THEN IT DONT EVEN WORK IT
Old Apr 3, 2008 | 07:51 PM
Pat_S's Avatar
Press your caps lock button once more. No need for screaming now.
Old Apr 3, 2008 | 07:57 PM
JDMguy88's Avatar
are you using the fuel from the year ago or did you put new fuel in the tank?
Old Apr 3, 2008 | 08:24 PM
g2daturbo's Avatar
Default Re: (JDMguy88)
put some new gas in it... any cel? white smoke is usually headgasket issue.. what is the condition of the newly installed engine??
Old Apr 4, 2008 | 08:44 AM
pearl404's Avatar
Default Re: (g2daturbo)
no i havent got a chance to drain the gas but, the motor was in great shape cause my bud bought it from me and it runs his car just fine. do you think that the fuel filter would cause such a thing? I dont think its in the wiring cause its been double checked and there is no cels. If anyone knows please let me know!
Old Apr 6, 2008 | 07:00 PM
pearl404's Avatar
Default Re: (pearl404)
I drained the gas out of the tank, and put a new filter put fresh 93 octane and it still does it. The motor is a fully built b18b1, but it did the same problem with the stock one
Old Apr 17, 2008 | 05:40 PM
pearl404's Avatar
Thanks guys for the info. but it wasnt anything anyone said, it was the o2 sensor so if anyone else has this problem it might not through any cels, and you can check the volts and its fine, but i changed it and it was the sensor.
Old Apr 17, 2008 | 06:21 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
OBD1 car which you have will be very hard to set a CEL, the criteria to set a CEL wasnt as strict as it is now with OBD2. As for the o2 sensor what tests did you do? Obviously it fixed it since you say it runs good now but an 02 sensor can look ok but may fail a sweep test makin it inefficient.
Amed Irizarry
11
Jul 30, 2011 12:55 PM
monsterb18b
17
Sep 14, 2009 10:55 AM
pearl404
Apr 6, 2008 06:50 PM
sxyflyttr
Jan 26, 2006 08:06 AM
JpiZz0
13
Feb 13, 2003 06:19 PM
