4 wire o2 sensor help
Old Apr 3, 2008 | 01:18 AM
blu_ej's Avatar
Default 4 wire o2 sensor help
So i got a gsr swap from a guy and swapped it in my 95 civic ex and I got a cel 43 (fuel supply system). i was told by a shop that it was just my o2. Checked o2 sensor and it was extended 2 ft and not soldered so I soldered the wire. Still getting the code. The o2 sensor is a denso 4 wire with 2 black, 1 white, and 1 green. If the 2 black are crossed would that make a problem? Any other ideas of what my problem could be please let me know. This code is starting to **** me off. I only get around 150 miles on a full tank. If there is a write up about this please point me in the direction I have searched and could not find anything. Thanks to whom ever helps me out.
Old Apr 13, 2008 | 03:36 PM
!hybrid's Avatar
Default Re: 4 wire o2 sensor help (blu_ej)
i do know if the black wires are crossed, you will get what you describe. what ECU do you have, and it's a B18C1, right?
ShortyzKustomz
Nov 1, 2007 06:24 PM
DarkBB4
Aug 28, 2005 09:35 AM
Driven
11
Aug 30, 2004 08:35 PM
xmd
Oct 12, 2003 10:38 AM
