water leaks?
water leaks?
I have a water leak in my trunk not to sure where its coming from checked around the seals and it doesn't look like anythings going threw them wheres the common areas it leaks from?
Also i have a water leak in front driver side slight water goes to the floor of my driver side and passenger side any body have these common problems?
H-T Order of Merit
Re: water leaks?
From what I've seen, when water leaks into the trunk, about 60 percent of the time it's caused by a leak in the taillight assembly (cracked lens, or the rubber seal, etc), about 20 percent of the time it's caused by a leak in the sunroof or hatch lid, and the other 20 percent of the time it's something else.
The water usually collects in the spare tire well. If you haven't checked around there recently, the leak may have been going on for quite a while.
