da idle problem?!
Old Mar 18, 2009 | 03:08 PM
toojdmforschool's Avatar
Default da idle problem?!
so I fired up my da today...and the idle is reallllly weird. the whole motor vibrates 10x harder, the idle rumbles like a harley, and the throttle response is weak. what could this be?!
Old Mar 18, 2009 | 05:29 PM
j_bizach's Avatar
Default Re: da idle problem?!
It sounds like you may hav a dead cyilder as thats usually the only thing that will make a motor shake that had. Check to make sure your getting spark to all cyilders. If that turns up good check ur compression if thats good make sure u dont need a tune up. Does it still drive?
Old Mar 19, 2009 | 12:06 PM
yeah it still drives. I checked all of the plug wires, I'm still getting spark, I checked the injectors and every cylinder's good. could it be timing or the distributor cap?
Old Mar 19, 2009 | 08:12 PM
j_bizach's Avatar
timing may be a good posibility with a da ur proly experiencing a sliped timing beltid pop off the valve cover and check ur timing marks
Dylanthoms
Apr 24, 2018 08:52 PM
NoVALude
Nov 20, 2006 11:02 AM
bassysingh
Oct 17, 2005 10:02 AM
dgie31
Oct 3, 2004 06:25 PM
ogwutang
May 5, 2003 05:36 PM
