lsv build
ok well i am building an ls vtec motor. and there is no acura dealer in town or anyone that can get me an gsr oil pump. my question is the b16 oil and water pump the same as the gsr?? i can get the b16 one from honda but i already have a gsr timing belt and almost everything else to finish my build. this is all thats holding me back lmk please
Use the gsr timing belt because your block is 1.8 like the gsr.
The b16 belt would be too short.
And the timing belt you use is determined by the water pump you use, NOT by what block or head you're using. B18B water pumps have 19 teeth, B18C1 pumps have 22 teeth. The B18C1 belt is longer as a result, and the B18C1 water pump spins slower, which pumps the water through better (less cavitation).
OP just order the parts you need online, like www.acuraautomotiveparts.org most likely it will be cheaper anyway.
To answer the question, 99-00 Si B16 water pumps were the same as 96-01 OBD2 Integra water pumps. OBD1 Integra and 93-95 del Sol VTEC water pumps had different part numbers, and I don't think they are interchangeable.
The 99-00 Si oil pump is also the same as 96-01 Integra oil pump. Same part numbers.
15100-P72-A01 OBD2 B16A/B18C1 oil pump
19200-P72-013 OBD2 B16A/B18C1 water pump
