turbo ???'s
Old Jan 20, 2004 | 07:41 PM
ebp 99 si's Avatar
Default turbo ???'s
i was wondering on which turbo i should go with
i have a h22type-s hatch and was wondering if i should keep the precision sc63 i have now and put on it or if i could benefit more from a precision pt72
what are the spool times on the pt72 and what are some of the differences between the 2 turbos
any input would be greatly appreciated
Old Jan 20, 2004 | 07:59 PM
PrecisionH23a's Avatar
Default Re: turbo ???'s (ebp 99 si)
Is your h22a fully built and are you planning on making over 700whp?
For a full list of precision specs check out:
http://www.precisionte.com/sportcompact.php
Of course the sc63 is generally going to spool faster then the pt72 will, but remember it depends on which trims you go with. I seriously doubt you will need a pt72.
Old Jan 20, 2004 | 08:14 PM
ebp 99 si's Avatar
Default Re: turbo ???'s (PrecisionH23a)
this year i'm keeping stock block...don't have enough money yet for what i want
next year it will be bored to 91mm and fully built
the specs on my sc63 are the 76 wheel trim and.63ar
if i would go withe the pt72 it would be with the .81ar
Old Jan 20, 2004 | 08:36 PM
TurboJesse
Guest
Posts: n/a
um...you worried that an sc63 is not gonna be big enough?
Old Jan 20, 2004 | 08:44 PM
boosted92's Avatar
Why do you want to run a PT72? If you're running a T3 housing SC63 right now, jumping to a PT72 could easily add 2000 RPM's of lag. That turbo will do damned near 800 to the wheels, I wouldn't be suprised if it could make 800 to the wheels. What are your ET/power goals for the car? I
Pete_SI
Aug 15, 2005 02:55 PM
Honda Sport
Dec 4, 2003 03:56 PM
bluedelsol
Jun 11, 2003 03:37 PM
