What Should I Do ?????
Old Jan 20, 2004 | 06:38 PM
jweezy225's Avatar
Default What Should I Do ?????
Whats up i am going LS Turbo in my hatch...but i have some questions...What Pistons and size should i put in my LS Motor??? and would it be reliable to just change my pistons and put a Turbo on?? or will my motor blow up in no time....im a noob when it comes to turbo, but i just got into the turbo scene ,and i want turbo... nothing sick...but i kno when i put a turbo on my LS Motor its going to feel real good...the reason why i asked about the pistons is because i read on here alot of people have Turbo on their stock LS Motors but i want to know how reliable is it??? Thanks Honda-Tech's Forced Induction
Would it be reliable to just change the pistons and put a turbo on?
Old Jan 20, 2004 | 06:46 PM
W C L's Avatar
Default Re: What Should I Do ????? (The Hulk)
if want to have a little extra insurance on your side, slap some rods and pistons in there and u'll be ok.... like u said u dont want get ridiclous with the setup so that probably rules sleeves out....
stock ls motor with good tuning and nothing over 11 lbs (pushin it ) should be jsut fine for what ur looking for.... as far as size u plan to bore it out u might as well get some rods and pistons... if not stick with stock bore if there is no need to bore it out...
remember, it jsut money, how much do u want to spend?!?!?!?!
hope i helped u some thanks...
Old Jan 20, 2004 | 06:47 PM
SpoonFed's Avatar
Well I would suggest 81mm JE pistons or even CP's 9:1 or 10... If u are going to replace the pistons you mind as well do the rods (Crower, Eagle ect) or even get the block sleeved... Its all up to you and it all comes down to how much money you have
nY's FiNeSt's Avatar
doing pistons and rods will help your bottom end alot, but honestly it has alot to do with how good you get it tuned and how you drive your car. will it be daily driven?
Old Jan 20, 2004 | 06:50 PM
jweezy225's Avatar
Default Re: What Should I Do ????? (W C L)
im not made of money at all but i kno i have my money for a turbo kit and pistons i saved up...yea the car will be daily driven thats why im not gettin crazy crazy with the turbo setup...just want some boost i kno i wont be going over 10 PSI
Old Jan 20, 2004 | 06:54 PM
suggestion: don't skimp out on a good fmu
happy boosting
Old Jan 20, 2004 | 07:01 PM
jweezy225's Avatar
Default Re: What Should I Do ????? (nY's FiNeSt)
alright im going to change the Pistons and Rods when i go turbo...what pistons and what rods do u turbo guys suggest???
Old Jan 20, 2004 | 07:11 PM
jweezy225's Avatar
i just need some suggestions on the exact Pistons and Rods i should get so ill know
Old Jan 20, 2004 | 07:21 PM
W C L's Avatar
hmmm its up to u.. do some searches on kidna products u like.... pistons are made of diff materials, comp ratio, which diff in prices.... same with the rods, diff material which hold more power and what not.... what i see alof of peeps using a eagle rods and cp and wiseco pistons... but like i say do a search on the products to see what ur lookin for...
i built 2 ls motor with that combo eagle/cp no problems for customers, i like that combo...
hiphop23j
Nov 10, 2007 06:48 PM
Scud
Jan 8, 2007 12:44 PM
allmotorgsrekk
Aug 20, 2006 08:13 PM
sushibug
Apr 12, 2002 05:36 AM
