ZEX Nitrous plus sc61 and sleeved motor..
I am currently running a sleeved fully built bottom end with the sc61. The car makes 310 hp and 250 ft lbs of trq at 15 psi with a solid 12-1 air fuel ratio. The car has so much power that it breaks loose the tires top end..I know those numbers arent great but it has a good powerband and with the addition of an intake manifold and throt body i know i will see alot more..have the dyno sheets if someone will post them for me.. Due to certain idiots talking **** at the local races i will be adding my dry zex nitrous kit. Is this possible? i Have 880cc precision injectors and hondata stage 2 b . Will the zex kit bumping up the fuel pressure give it enough fuel to operate safely at a 50 shot ? I know its better to go wet but will the dry kit work for this one big race ?I dont plan on hitting it till 4th gear as i will not get traction. anyone ever tried this out?
Re: ZEX Nitrous plus sc61 and sleeved motor.. (GSRT37)
Tune Tune Tune, nitrous and turbos love each other. I wouldn't feel safe running it without tuning the nitrous first.
-Ryan
-Ryan
