internal wastegate possible to run open loop?
Old Jan 20, 2004 | 03:24 PM
18gLUDE's Avatar
Default internal wastegate possible to run open loop?
i just wanna know if it's possible to dump the 18g's internal wastegate's air into the atmosphere rather than back into the exhaust. if it is possible has anyone done it and how do u do it? i have heard that on the fmax kit this adds a bunch of hp.
Old Jan 20, 2004 | 03:27 PM
Bailhatch's Avatar
Default Re: internal wastegate possible to run open loop? (18gLUDE)
um, ya it is very common on DSMs. Forced Performance sells flanges for this. You can make you own pretty easily too. It would give you some good exhaust flow at full boost
Old Jan 20, 2004 | 05:15 PM
18gLUDE's Avatar
Default Re: internal wastegate possible to run open loop? (Bailhatch)
anyone have a detailed description or know of a site with a good write up on how this is done?
Old Jan 20, 2004 | 06:38 PM
Bailhatch's Avatar
here is the flange off the FP.com site, since you didn't look it up.
http://linux.forcedperformance...-GSFL
basicly the DP is welded to the big hole and a dump tube is welded to the small WG hole. it's pretty simple.
I think there are some places that have O2 housings for either DSM or jdm t25/28s. basicly that flange with little flanged elbows welded to it. you could disable the internal gate and put an external on too if you wanted.
Old Jan 20, 2004 | 07:19 PM
18gLUDE's Avatar
thanks a lot.
dagle
Feb 9, 2008 12:51 PM
H2on0da3
Welding / Fabrication
Jan 5, 2006 01:18 PM
SPOOLINmatt
Jan 12, 2005 07:51 AM
KevronsEG
Mar 8, 2004 04:38 PM
udctown
Sep 13, 2001 07:50 AM
