external wastegate and standalone = wg spring question
im about to order an external wastegate but i can not decide which wastegate spring im going to get
im running a standalone computer , so does it matter which wg spring i get ???
say if i get 1bar wg spring , will still be able to boost lower than 1bar ?
thanks in advance
thanks in advance
Re: external wastegate and standalone = wg spring question (Day Walker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day Walker »</TD></TR><TR><TD CLASS="quote">
thanks in advance</TD></TR></TABLE>
no
no
Re: external wastegate and standalone = wg spring question (MaxSterling)
um.. what does it matter if you have a standalone or not?, why does that affect the wastegate?... , get the correct rate wastegate spring, if you want to boost 10 psi get a 10 psi spring, and if you want to boost more you can boost more with a boost controller, you can never boost lower than the rate of the w/g spring
powerdbygarrett
07-03-2008 01:50 PM
95srv
05-12-2006 07:09 AM
