Need help w/ gsr block setup...
Old Jan 19, 2004 | 02:03 PM
dEtSoOb's Avatar
Default Need help w/ gsr block setup...
I'm swapping in a gsr block to replace my b16 block for my setup, and wanted to build it a little before throwing it in. I would like to be around 300-350 whp in the car, and am wondering what I should do to the block to make sure it will be ok. Obviously the car will be getting tuned. I was thinking JE 9:1 pistons and eagle rods. And having the pistons matched to the block. Would that setup be fine or should I be changing some things/adding more parts?
Old Jan 19, 2004 | 02:08 PM
Adriano's Avatar
Default Re: Need help w/ gsr block setup... (HKesque)
For 300-350hp it should be fine. I would change stuff like water pump and oil pump while rebuilding. If you get it sleeved, it will be even better. Just make sure you get it tuned properly.
Old Jan 19, 2004 | 04:09 PM
dEtSoOb's Avatar
Default Re: Need help w/ gsr block setup... (brryder)
How big of a difference is sleeving going to make for that hp?
Old Jan 19, 2004 | 04:21 PM
Nextelbuddy's Avatar
hey man. i made 326 @ 12 psi on stock internals.
i just bought JE pistons9:1 compression, eagle H bea, rods and a golden eagle block guard. im goin for 450-500 to the wheels. i know i can do it. so u shoudl too.
Old Jan 19, 2004 | 04:30 PM
grndcont's Avatar
fu@ker! i only made 296hp @12 on stock internals!!! oh well, it was just a stock greddy kit with the blue box. by the way original poster, it did'nt last long like this. just pistons + rods should be fine. but with the other stuff like water pumps, and belts...be smart, if it was ment to ware out, replace it.
Old Jan 19, 2004 | 11:02 PM
dEtSoOb's Avatar
Default Re: Need help w/ gsr block setup... (nextelbuddy)
that setup you just bought is actually the exact setup i was thinking about so I guess I will be ok then.
Old Jan 20, 2004 | 01:17 PM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HKesque &raquo;</TD></TR><TR><TD CLASS="quote">I'm swapping in a gsr block to replace my b16 block for my setup, and wanted to build it a little before throwing it in. I would like to be around 300-350 whp in the car, and am wondering what I should do to the block to make sure it will be ok. Obviously the car will be getting tuned. I was thinking JE 9:1 pistons and eagle rods. And having the pistons matched to the block. Would that setup be fine or should I be changing some things/adding more parts?</TD></TR></TABLE>
I'm in the same process..PM'd u
Old Jan 20, 2004 | 01:35 PM
rocket256's Avatar
A T3/T4 @ 15psi and you are there easy!
Old Jan 22, 2004 | 01:38 PM
dEtSoOb's Avatar
Default Re: Need help w/ gsr block setup... (4-banging)
I tried to pm you back, but I guess since I am still a trial user I am not able to use that option.
thugsbryan
Mar 27, 2015 09:48 AM
GT500FTW
Nov 3, 2014 02:32 PM
chimmike
Apr 28, 2008 01:02 PM
SSBPGSR
Mar 21, 2005 06:36 AM
