check out my vafc settings after wideband install
I got my wideband in today and was able to fine tune my vafc settings. I have a 99 si with a vortech supercharger at 8 psi with 440 injectors.
Before the wideband, settings were as follows
rpm low & high
1000 -40
1500 -40
2000 -39
2500 -39
3000 -38
3500 -38
4000 -37
4500 -37
and so on....you get the point
and i was gettin a high of .53 bar on my vafc...stayin around .49 as a high most of the time.
With the wideband here are my street tuned settings
rpm low hi
1000 -47 -40
1500 -46 -41
2000 -43 -41
2500 -43 -41
3000 -43 -41
3500 -43 -40
4000 -42 -40
4500 -41 -40
5000 -39 -39
5500 -39 -39
6000 -39 -39
7000 -40 -40
8000 -40 -41
9000 -42 -42
now i am gettin a high of .55 bar.
these settings yeild me about 14.5 out of boost and 12-12.5 in boost with it goin to about 10.5 at 7500rmp.
I was very suprised at how much i was able to lean it out in the high rpm's. When i first got the wideband in and took it for a test drive, from 4000 on at full throtel, the wideband just said rich. as rich as it goes is 10.0:1. I feel like i picked up quite a bit of top end power, and im not really gettin traction at all in 2nd (shitty tires)
Anyway, i just wanted to share
rpm low & high
1000 -40
1500 -40
2000 -39
2500 -39
3000 -38
3500 -38
4000 -37
4500 -37
rpm low hi
1000 -47 -40
1500 -46 -41
2000 -43 -41
2500 -43 -41
3000 -43 -41
3500 -43 -40
4000 -42 -40
4500 -41 -40
5000 -39 -39
5500 -39 -39
6000 -39 -39
7000 -40 -40
8000 -40 -41
9000 -42 -42
Re: check out my vafc settings after wideband install (slammin86)
Nice work. Looks like you really cleaned up the top end. Those things are worth every penny!
Screw you guys, I'm... going... home.
Why are you keeping it so rich (10.5) from 7500 on up? I thought you could safely run it at about 12.0 to redline and pick up some more top end. Just curious.
Re: check out my vafc settings after wideband install (mctonyb)
Cool, just ordered the parts to make a WB. How is the A/F under part throttle/ part boost? What was your tuning method and how long did it take? any other changes you have noticed? Thanks!
Re: check out my vafc settings after wideband install (tjbizzo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo »</TD></TR><TR><TD CLASS="quote">Why are you keeping it so rich (10.5) from 7500 on up? I thought you could safely run it at about 12.0 to redline and pick up some more top end. Just curious. </TD></TR></TABLE>
Cause i was gettin tired that night so i stopped messing with it.
my new top end settings are as follows
4500 -40
5000 -40
5500 -40
6000 -42
7000 -44
8000 -47
9000 -47
as you can see there was still room for improvement.....lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">Cool, just ordered the parts to make a WB. How is the A/F under part throttle/ part boost? What was your tuning method and how long did it take? any other changes you have noticed? Thanks!</TD></TR></TABLE>
ive just been tweakin it as i drive....the main change i noticed is more traction problems...lol
4500 -40
5000 -40
5500 -40
6000 -42
7000 -44
8000 -47
9000 -47
Re: check out my vafc settings after wideband install (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle »</TD></TR><TR><TD CLASS="quote">damn, that's awesome! Thanks for the comparison man. I always wanted to see a before and after </TD></TR></TABLE>
i also did some more fine tuning on my part throtel low end settings
1000 -49
1500 -46
2000 -45
2500 -45
3000 -45
3500 -45
4000 -45
4500 -44
i still cant believe how rich i was running before
1000 -49
1500 -46
2000 -45
2500 -45
3000 -45
3500 -45
4000 -45
4500 -44
Ya the comparison is really interesting. What is your TH% for Hi and Lo throttle?
Can you really tune the low throttle much below 60%? I thought the ecu would take over once it switched back to closed loop.
Re: check out my vafc settings after wideband install (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">Ya the comparison is really interesting. What is your TH% for Hi and Lo throttle?
Can you really tune the low throttle much below 60%? I thought the ecu would take over once it switched back to closed loop. </TD></TR></TABLE>
the crossover from low to high is 70-71%
Im not having a problem leaning it out at low throttle
woulden't the ecu try and bring it back to a leaner (than turbo needs) AFR anyway when in closed loop?
I wonder if you can richen up the part throttle because my turbo loves to boost 1-5psi at part throttle (under 30%). or maybe I'll just set my TH to 10% & 30% or something.
That 47% at 1000RPM is what really interests me. That's exactly what I was talking about. I dont think you can do that w/the DSM 450's though.
Did Idle and startup improve drastically? I have a feeling it did.
Also, ur using RC injectors right?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle »</TD></TR><TR><TD CLASS="quote">That 47% at 1000RPM is what really interests me. That's exactly what I was talking about. I dont think you can do that w/the DSM 450's though.
I'll verify that you cannot. I've got the DSM 450 "black-tops" and I have my 1000 setting to something like -25 or -17. THats what yields the smoothest idle. At around -40% my car's struggling to idle at like 300rpm-500rpm.
Also, ur using RC injectors right?</TD></TR></TABLE>
I am using precision 440 injectors....
my idle is now at -47...idles very very smooth at about 700 rpm
the only problem i am having is code 13......any ideas on how to get rid of this
Re: check out my vafc settings after wideband install (GPoodle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GPoodle »</TD></TR><TR><TD CLASS="quote">
I'll verify that you cannot. I've got the DSM 450 "black-tops" and I have my 1000 setting to something like -25 or -17. THats what yields the smoothest idle. At around -40% my car's struggling to idle at like 300rpm-500rpm.</TD></TR></TABLE>
Yeah the 450's have some lag in them. I brought up a topic like this before and that's what was explained to me. I've actually got mine at 35% and it's not too bad right now. But i've seen both setups work.
Yeah the 450's have some lag in them. I brought up a topic like this before and that's what was explained to me. I've actually got mine at 35% and it's not too bad right now. But i've seen both setups work.</TD></TR></TABLE>
the only problem i have is if i am stopped and try to hold the rpm between 2000 and 4000 rpm....if i try to do this, it cuts out on me every few seconds....do you have a similiar problem?
