Planning a turbo project
Old Jan 20, 2004 | 03:50 PM
theBird's Avatar
Default Planning a turbo project
I want a mild turbo setup on my b18b with around 275-300whp and be ABLE to rev to 8k. This is my only car and I drive it daily. Right now, I just want to prep for turbo, then bolt on the turbo when I have the funds. I am unsure about the brands of parts I am going with.
First off, I want to rebuild the bottom end with aftermarket rods, head & rod bolts and pistons with a stock compression ratio. I am not going to sleeve it b/c if I like this turbo stuff I'm going all out later on when I have more money.
Since I want to go stock 81mm bore, will I have to get oversized pistons like 81.5mm b/c of cylinder wear after 140,xxx miles on the engine?
I will upgrade the valve springs and retainers and thats it right now for the head.
For fuel management I was looking at hondata and I am still kinda clueless as to which chip I will want to run. Bigger injectors and ignition system will also be upgraded with the rebuild before turbo.
Is there anything I am overlooking so far? Sorry for being a n00b.
Old Jan 20, 2004 | 05:42 PM
theBird's Avatar
Help me out please.
Old Jan 20, 2004 | 06:27 PM
951's Avatar
951
Default Re: Planning a turbo project (theBird)
dont forget the brakes! going from a stock integra to 300 whp with no brakes = one wrecked integra.
Old Jan 20, 2004 | 06:39 PM
Egg-weezy's Avatar
how about more fuel. Pump, reg, rail?
Or ignition, wires, cap, coil, plugs
Old Jan 20, 2004 | 07:10 PM
theBird's Avatar
Default Re: (dainteg)
ah yes the fuel pump, reg and rail...forgot about the source of all of this power. THX
but what about piston sizing?
blub16hatch
Dec 27, 2006 03:41 PM
turboDerrick
Dec 15, 2006 11:17 AM
Dasani
Jul 5, 2006 02:39 PM
broketuner-Sol_Si
Jan 26, 2006 05:08 PM
JdmLsPwr425
Mar 8, 2004 12:46 PM
