boosting
Old Jan 19, 2004 | 07:11 PM
Dasavior's Avatar
Default boosting
how many psi can the b18 take stock with 87,50mi on it and it has had every oil change on time and stuff like that i have the records in my car just wondering about boosting.
Modified by Dasavior at 4:23 AM 1/20/2004
Old Jan 19, 2004 | 07:20 PM
thaiphob's Avatar
Nikon!!!
Default Re: boosting (Dasavior)
there is no X amount of psi a type of block can take. it varies from motor to motor, plus it depends on mileage, condition etc. your question has more questions than answers.
Old Jan 19, 2004 | 08:07 PM
Boost Ambassador's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasavior &raquo;</TD></TR><TR><TD CLASS="quote">how many psi can the b18 take stock with 87,50mi on it and it has had every oil change on time and stuff like that i have the records in my car just wondering about boosting.
Modified by Dasavior at 4:23 AM 1/20/2004</TD></TR></TABLE>
Stock B18's are capable of holding up to 11-12 psi pending on what fuel management u go with... Hondata, AEM programable, etc.
Old Jan 19, 2004 | 08:58 PM
Deluzional's Avatar
Default Re: boosting (LS60-1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS60-1 &raquo;</TD></TR><TR><TD CLASS="quote">
Stock B18's are capable of holding up to 11-12 psi pending on what fuel management u go with... Hondata, AEM programable, etc.</TD></TR></TABLE>
With a good fuel management system you can go beyond 12psi on your motor, its been done numerous times by several individuals on this board. But as thaiphob stated, each engine varies
Old Jan 20, 2004 | 05:11 AM
RedTegLS's Avatar
Default Re: boosting (Deluzional)
I would also like to add if you search in the foced induction archieves you will find more information you will ever be able to take in!
Old Jan 20, 2004 | 05:42 AM
quikB18B's Avatar
Default Re: boosting (RedTegLS)
Just to add to what's been said, you should use whp instead of Psi to measure it's limits. 10 psi on a big turob is not the same thing as 10 psi on a small turbo. I would say 300 whp is nearing or approaching the limit of a stock b18b, whether it takes 10 psi or 15 psi, is up to the size of the turbo .
Old Jan 20, 2004 | 06:13 AM
mEr's Avatar
mEr
Default Re: boosting (quikB18B)
I would say don't exceed 10-12 psi on the stock bottom end with that amount of mileage, but quikB18B said it the best, size of turbo's make a big difference!
Old Jan 20, 2004 | 08:03 AM
Del_Slowest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">Just to add to what's been said, you should use whp instead of Psi to measure it's limits. 10 psi on a big turob is not the same thing as 10 psi on a small turbo. I would say 300 whp is nearing or approaching the limit of a stock b18b, whether it takes 10 psi or 15 psi, is up to the size of the turbo .</TD></TR></TABLE>
Don't listen to this guy. Also don't pay attention to the big post a few weeks ago where i compared the SC61 and the T-25 on psi levels and WHP. Put the SC61 on your car and boost it to the suggested 10-15psi like everyones saying. Just make sure you videotape it when it throws the rod into the block/head
BTW- i say 10psi with a small turbo such as the T3 or the greddy turbo.
Old Jan 20, 2004 | 09:06 AM
mEr's Avatar
mEr
Default Re: boosting (Del_Slowest)
T25 @ 10psi, or the like!!!
Old Jan 20, 2004 | 09:11 AM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest &raquo;</TD></TR><TR><TD CLASS="quote">
10psi with a smaller turbo will give you ~230whp, you can easily make 300whp...who cares how much boost it takes. I know boosted-hybrid ran acouple of the greddy kits to 17-18psi on stock b18b's..
Old Jan 20, 2004 | 10:06 AM
G
sh!t happens.
Default Re: boosting (Mpir3)
i have 160k on my b17 motor and i run 5 psi ever day driving and 9 psi when i get bored or want to race something worth racing on 9 psi. just make sure you have good fuel management...
Old Jan 20, 2004 | 10:37 AM
quikB18B's Avatar
Edited
Modified by quikB18B at 4:36 PM 1/20/2004
Old Jan 20, 2004 | 01:22 PM
I was merely telling him to boost 10-15psi on a T3 or a T3/4 turbo. that would put him around the 280-300whp range. I was also telling him NOT to boost 10-15psi on a SC61 or a large turbo b/c that would put him way past 300whp and end up making him throw a rod. Sorry if my other post wasn't clear enough. It was meant to be sarcastic
Old Jan 20, 2004 | 01:35 PM
quikB18B's Avatar
Okay sorry for being an *** then
I read your post like 3-4 times and i couldn't tell if you were being a funny guy, or being sarcastic All i saw was that you said don't listen to this guy
Internet, the hardest place to understand sarcasm.
Post edited
Old Jan 20, 2004 | 01:43 PM
rtype11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">Okay sorry for being an *** then
Post edited </TD></TR></TABLE>
see if this is serious or sarcastic - you can easily hold 35PSI once!
Jun 12, 2009 06:49 PM
tdark1582
Apr 10, 2007 06:16 AM
tdark1582
Apr 9, 2007 08:19 PM
88crxhfb16
Apr 19, 2006 01:48 PM
sikcrx80
Aug 4, 2003 09:23 AM
