Ceramic Coating pistons and head
Old Jan 20, 2004 | 10:03 PM
Mark817teg's Avatar
Default Ceramic Coating pistons and head
I searched and did not find anything. What order do I need to follow. Ill be running arias custom pistons and want them coated. do I get the block machined for the pistons, then send off the pistons and head or vise versa.
Also, how will the coating affect the compression ratio, how thick is the coating.
My last question is I want my header and turbine housing coated, can you color the ceramic coating?
Would powder coatin be an alternative to cermic on the external parts, being I know it can be colored? would it serve as the ceramic would as far as insulation?
Old Jan 21, 2004 | 04:25 AM
hpfsi's Avatar
Default Re: Ceramic Coating pistons and head (Mark817teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mark817teg &raquo;</TD></TR><TR><TD CLASS="quote">I searched and did not find anything. What order do I need to follow. Ill be running arias custom pistons and want them coated. do I get the block machined for the pistons, then send off the pistons and head or vise versa.
Would powder coatin be an alternative to cermic on the external parts, being I know it can be colored? would it serve as the ceramic would as far as insulation?</TD></TR></TABLE>
1) I'd coat the pistons then have the cylinders bored - but you might ask the coating company what they recommend. For pistons I'd go with Swain Tech.
2) The coating isn't thick enough the effect the comp. ratio any measurable amount.
3) Yes there are different colors, some places can do some very unique colors (common colors - silver, black, grey, white etc)
4) If the part is going to see any elevated temperatures, I'd lean towards the ceramic coating. At what point it is too hot for powder coating I do not know.
http://www.swaintech.com/race.html
http://www.jet-hot.com/pages/racing.html
Old Jan 21, 2004 | 05:57 AM
TrueNorthStar's Avatar
Default Re: Ceramic Coating pistons and head (hpfsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpfsi &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.jet-hot.com/pages/racing.html</TD></TR></TABLE>
You forgot one:
http://www.hpcoatings.com/
devious_yeti
May 2, 2016 07:30 PM
James_Starks
16
Sep 27, 2010 09:05 PM
hondaluva
11
Apr 26, 2005 07:27 PM
KoRE
Nov 24, 2003 07:18 PM
blazin
Jul 11, 2003 06:11 AM
