nitrous 3 stage controller,would this work?
Old Jan 21, 2004 | 05:26 AM
civictypenos's Avatar
Default nitrous 3 stage controller,would this work?
im putting a 100 shot on.i want to have some sort of progressive type controller but i dont care to spend $400+ DOLLARS FOR ONE.i though of a possable way to make a 3 step controller.using a 3 window rpm switch,with 1500,2500 and 3500 pills,then using 2 radio shack potentiometers(msp).i would wire the 2 pots up with the 1500 and 2500 pills,adjust the voltage on them to allow them to NOT open all the way,then at 3500 no pot becuase it would be at full voltage.i could use the pots to adjust the voltage to what ever my car will handle traction wise.
does this make any sense,could it be done any other way??input please
Old Jan 21, 2004 | 09:43 AM
Default Re: nitrous 3 stage controller,would this work? (civictypenos)
ttt
Old Jan 22, 2004 | 05:04 AM
no body?
Old Jan 22, 2004 | 05:17 AM
ZoRG's Avatar
Your potentiometer idea might not work that well, try rather using a 3 way controller that pulses the solenoids... even a 2 stage will be fine, you don't really need a 3 stage...
Is this for a direct port? of mixed?
Old Jan 22, 2004 | 06:28 AM
Default Re: nitrous 3 stage controller,would this work? (ZoRG)
im going to be using a wet nx kit.so the controllers actually pulse the soliniods?that makes since.where can i find a 2 stage from??
Old Jan 22, 2004 | 09:22 PM
ZoRG's Avatar
You have 2 options, you can buy 2 kits, one without a bottle, or you can get a V8 kit, since the V8 kits have 2 sets of solenoids, you can use it as a 2 stage.
C-187
Paint and Body
Jun 23, 2008 06:32 PM
shant
Apr 1, 2006 07:40 PM
hotimportcrx
Sep 19, 2005 04:52 PM
hotimportcrx
civictypenos
Jan 22, 2004 05:55 PM
