Valve overlap?
Old Jan 20, 2004 | 09:29 AM
revhigh96's Avatar
Default Valve overlap?
yes I have allready searched and didnt find all the info I was looking for.
my current setup is a built and turbo'd B18C5 with a stock head. I know when my car goes into vtec (maybe even before I dont know) there is some valve overlap that allows boost to escape before the exhaust valves close. Are there things that can help decrease this? I dont have adjustable cam gears yet, would tuning that help? I have seen people go over to an aftermarket non-vtec cam, will this make my car a lot less daily driveable?
I'm just looking to get the max performance out of my car just like everybody else. So please post any info that you know that might help. And PLEASE correct me if I am wrong about anything.
Thanks,
-Mike
Old Jan 20, 2004 | 10:33 AM
Kataku2K3's Avatar
Default Re: Valve overlap? (revhigh96)
I guess the simplest answer to your question is yes, there is a little overlap with the cams you are running now... Is it that big of a deal? No, not really... If you do want to decrease overlap a tad then just throw some GSR cams in there, I doubt you'll notice any difference tho... We and a lot of other people have made 600-700whp on stock GSR cams, if you're making more than that a lot of people run ITR's... Don't get me wrong tho, we've done a lot of stock B18C5 turbos and they've all worked fine with stock cams... Just my $0.02
Old Jan 20, 2004 | 11:05 AM
kpt4321's Avatar
You want to have some overlap, it's a good thing.
Old Jan 20, 2004 | 11:34 AM
revhigh96's Avatar
Default Re: (kpt4321)
I thought overlap was only good on N/A cars? am I wrong?
Old Jan 20, 2004 | 11:42 AM
Lsos's Avatar
From what I understand most people have this backwards....valve overlap doesn't cause boost to escape out the exhaust valves, it causes the exhaust to go back into the combustion chamber (probably even worse than letting boost escape). This is because in most cases except for hardcore race cars the exhaust backpressure is higher than the intake pressure. That's why on VTEC cars you want a bigger than normal turbine to minimize that backpressure...as well as a big exhaust.
But anyways, I don't know the answer to your question....
Old Jan 20, 2004 | 05:38 PM
revhigh96's Avatar
any body else have any info on this topic? I know there are some really knowledgable people here on H-T
Old Jan 21, 2004 | 10:10 AM
kpt4321's Avatar
Factory turbos car have valve overlap.
Old Jan 21, 2004 | 11:53 AM
mike1114's Avatar
I recently spoke to a guy with a GSR w/ITR cams completly dynoed. He picked up 12whp but switching out the ITR's for GSR's cause of the overlap.
I have crower stage one cams in my GSR right now, they seem to be hurting my perfomance bad when you look at the graph. My tq just levels out from vtec on.
I picked up a set of stock GSR recently, gonna see if they do better.
Old Jan 21, 2004 | 12:01 PM
revhigh96's Avatar
Default Re: (mike1114)
do you know what the setup of the guy with GSR cams was? like how much boost he was running with what size turbo?
Old Jan 21, 2004 | 02:50 PM
kpt4321's Avatar
If your Crower cams are a non-turbo cam, then it is true that you probably will lose power with them when you go to a turbo setup.
You do want some overlap, without it motors will run like crap. However, cams optimized for NA setups often will not work well for turbos.
In a lot of cases, if a cars comes from the factory with a well-sorted set of cams (like the B18C does), then they will work well with a turbo.
BoostedEM1!
Feb 4, 2012 04:31 PM
ef-hatchcrap
13
Mar 10, 2010 10:28 PM
SLOAZZ95
Sep 14, 2004 11:39 AM
civicmark
Jun 26, 2002 09:39 PM
vwandhondaboy
Dec 26, 2001 11:37 AM
