need help on IC piping size please
Old Jan 19, 2004 | 01:20 AM
EFb18b's Avatar
Default need help on IC piping size please
I tried a search and it seems that 99.99% of the people out there are only trying to meet 250-400hp. Well, I'm looking more for a 600-650hp goal and I want to make sure the IC pipiing I get it right. I am looking to drag race my car with a b18c1 and pt67 turbo probably pushing anywhere between 20-30psi. I have not picked up an IC yet because I am having an even bigger issue there(size, air/liquid, air/air etc etc)
Any help will be appreciated
Old Jan 19, 2004 | 06:54 AM
redboost10's Avatar
Default Re: need help on IC piping size please (Redlineracer)
i have a honda/acura turbo book and im just going by the book, it says for 400hp and more 2.5" will work, no need for bigger than that.
Old Jan 19, 2004 | 07:04 AM
Ri5e's Avatar
Default Re: need help on IC piping size please (tgh99si)
2.25 is good enough for 600 WHP+
Old Jan 19, 2004 | 08:15 AM
TurboLSVtecTeg's Avatar
Default Re: need help on IC piping size please (BG Boost)
I would say 2.5" at most. Now if your going for crazy HP like over 700+hp. Then you might want to run 3". But the bigger piping will create more lag. Maybe not a significant amount but it will be there nonetheless. Right now I have 2" from the compressor to the intercooler. Then 2 1/4" from the intercooler to the charge pipe and the charge pipe is 2 1/2". Basically what comes with the Rev Hard Stage 2C Kit. I do plan on upgrading to 2.5" piping in the future with a bigger turbo. But for now it works fine. I mean unless you tried to run something like 1.5" piping. I really dont see any problems for the normal steet car.
Old Jan 19, 2004 | 11:46 AM
EFb18b's Avatar
Default Re: need help on IC piping size please (TurboLSVtecTeg)
Thanks for the help guys. I was thinking 2.5in would be fine but I just wanted to make sure.
Old Jan 19, 2004 | 12:01 PM
hulkhb's Avatar
yea 2.5 you should be fine
RattyTuned
Feb 2, 2018 01:13 PM
kidn1980
Jun 15, 2012 04:10 PM
thelate1
Jun 19, 2006 07:04 PM
killablaze
Dec 1, 2005 04:18 PM
Smokinsax
Jan 26, 2004 11:00 PM
