possible change of plans
Old Jan 17, 2004 | 09:19 PM
importpower's Avatar
Default d16 v h22
I've been extensively researching turboing a d16z6 in a 92-95 civic ex, collecting a few parts on the way. I've found some cars but in the process i've come across two (94 and 95) vtec preludes that are in my budget. There are plentiful parts and available info on turboing a d16 but I don't know a lot about turboing h22's. I was planning on using uberdata for fuel management and am unsure if it will work on h22s. Is it a lot harder to turbo a h22 and is it a lot different than d16s? I think i'll have to get a new turbo if i go h22 because the one I have is a t3 with a trim of 42/48 (i think). I planned on running 10 psi on a d16, what should I run a h22 on to make considerable power? Keep in mind this will be my first turbo project. Should I go turbo d16 or h22?
Modified by importpower at 12:20 AM 1/19/2004
Old Jan 18, 2004 | 01:02 PM
Default Re: possible change of plans (importpower)
bump
Old Jan 18, 2004 | 03:20 PM
Default Re: d16 v h22 (importpower)
bump
Old Jan 18, 2004 | 03:34 PM
rtype11's Avatar
you're really asking for a lot of opinions, some may not be popular so nobody is answering right now.
Old Jan 20, 2004 | 01:01 AM
Maintenance's Avatar
Uberdata does work with a h22. You either need to get a p28 or p72 ecu. Get a basemap of h22 rom. And start modifing it with uberdata, adding boost, retard ignition, and so fourth. I'm going to being boost my ride next month. I'm also going to be using Uberdata 1.64 with 440 cc injectors. I'm just waiting for all the parts to complete my turbo kit.
Its really up to you. If you want to take the d16 go for it. Same concept tuning still applies to both motor. If you need help with boosting the h22 and using Uberdata hit me up I'll try to guide you through it. But i should be done by next month. And let you know how it turns out
Old Jan 20, 2004 | 04:25 AM
scatuli's Avatar
Default Re: d16 v h22 (racerxfear)
just remember that if you turbo the prelude you wont be able to run very much boost at all
Old Jan 20, 2004 | 04:48 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: d16 v h22 (scatuli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scatuli &raquo;</TD></TR><TR><TD CLASS="quote">just remember that if you turbo the prelude you wont be able to run very much boost at all</TD></TR></TABLE>
hmm.. doesn't that really depend on whats done to the engine. If he upgrades intrenals and runs a good Fuel management system... i think it could do well.
piddy0110
56
Jul 2, 2009 05:51 AM
theERAisBack
Sep 19, 2007 01:48 AM
ludekid4323
Dec 6, 2006 11:57 AM
turbo boost
Sep 15, 2006 12:40 PM
