How much drag when doing a valve adjustment?
Old Jan 19, 2004 | 06:40 PM
Hoosier Daddy's Avatar
Default How much drag when doing a valve adjustment?
Just wondering how much drag I should feel on the feeler gauge when doing a valve adjustment. Thanks
Old Jan 19, 2004 | 07:30 PM
Bnjmn's Avatar
Default Re: How much drag when doing a valve adjustment? (Hoosier Daddy)
Well it is between 2 values. I did it so the lowest value had a bit of drag- so it barely fit. And then the next value up slid freely.
Old Jan 19, 2004 | 08:10 PM
psi420's Avatar
Snug enough to where your next size up gauge won't fit.
Old Jan 19, 2004 | 08:31 PM
Suprdave's Avatar
Default Re: (psi420)
Leave the feeler gauge in when you tighten the nut...shud still be able to pull it out after you tighten it...
Big mistake people make.
Old Jan 19, 2004 | 08:54 PM
Default Re: How much drag when doing a valve adjustment? (Bnjmn)
Thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">Well it is between 2 values. I did it so the lowest value had a bit of drag- so it barely fit. And then the next value up slid freely. </TD></TR></TABLE>
That confused me. Two values?
Old Jan 19, 2004 | 10:50 PM
CRX-RX's Avatar
Slight drag is the key. Just to where you start to feel some drag and no more. If it's really tight and hard to move, you are at the next size down.
Old Jan 27, 2004 | 09:52 AM
myhatchrips's Avatar
eventually you'll gain a feel for it
Old Jan 27, 2004 | 10:18 AM
Rory Breaker's Avatar
Default Re: How much drag when doing a valve adjustment? (myhatchrips)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips &raquo;</TD></TR><TR><TD CLASS="quote">eventually you'll gain a feel for it </TD></TR></TABLE>
You will. The term "slight drag" is what will throw you off. Think about it this way...the size of the feeler guage you are using is the amount of gap you want. So enough that its in there snug, but you can still pull it out. Try and ignore the term "slight drag."
Old Jan 27, 2004 | 10:25 AM
Kataku2K3's Avatar
Default Re: How much drag when doing a valve adjustment? (newgsrdriver)
Everyones covered it fine so far but just to add a bit more if you can get the feeler gauge between the rocker and the cam (even if it takes a lot of pressure), that's your clearance...
Old Jan 27, 2004 | 10:30 AM
tilt's Avatar
slight drag is a very subjective statement. just do it to where the next size larger gauge doesnt fit.
Old Jan 27, 2004 | 10:34 AM
Suprdave's Avatar
Default Re: How much drag when doing a valve adjustment? (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Everyones covered it fine so far but just to add a bit more if you can get the feeler gauge between the rocker and the cam (even if it takes a lot of pressure), that's your clearance...</TD></TR></TABLE>
Basically what I was saying...
Honda knowledge
Engine Management and Tuning
Dec 10, 2013 11:13 PM
jdmkha
Aug 5, 2010 12:12 PM
A_Rotary_Guy
Feb 22, 2008 10:25 AM
A_Rotary_Guy
Jan 20, 2008 11:54 AM
CardDealer
Mar 10, 2004 06:25 PM
