check engine light won't go off...
Old Jan 20, 2004 | 09:38 AM
turbosi03's Avatar
Default check engine light won't go off... got it!
Hey guys, my engine light has been on since I swapped in a stock b16a2 motor (kept the turbo bolted on)... I suspected that it would be my map sensor because I didn't have the missing link attached, and I'm using the stock map sensor. The ECU told me it was code 3, which somewhere on this forum is a chart that says 3 = map sensor.
I added the missing link, reset the ecu and the engine light is still on. I swapped the map sensor out with another one of the same, reset the ecu and engine light is still on... oh, and I have the P72 GSR ECU if that matters... running the b16 not tuned... I know...
My method of reseting the ecu was to disconnect the +battery for about 15min then reconnect...
any idea's on where to look next? or maybe someone knows the answer?
Thanks for any help...
Modified by turbosi03 at 12:21 AM 1/22/2004
Old Jan 20, 2004 | 09:46 AM
FULLTHROTTLE's Avatar
Default Re: check engine light won't go off... (turbosi03)
If it is coding up as soon as you turn the key on it has a wiring problem or a sensor failure. Instead of throwing new parts at the car it should be diagnosed using a factory service manual or helms manual. It could be wired wrong, could be a bad sensor, could be a lot of things.
Old Jan 20, 2004 | 12:02 PM
civicshowracing65's Avatar
maybe you didn't reset the ecu correctly. For my civic, from the fuse box I pulled out the 7.5A fuse. Or if yours is a different number, it's the backup radio fuse.
Old Jan 20, 2004 | 02:24 PM
BoostedSi's Avatar
Default Re: check engine light won't go off... (civicshowracing65)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicshowracing65 &raquo;</TD></TR><TR><TD CLASS="quote">maybe you didn't reset the ecu correctly. For my civic, from the fuse box I pulled out the 7.5A fuse. Or if yours is a different number, it's the backup radio fuse.</TD></TR></TABLE>
You dont have to take the fuse out to reset it. You can just disconnect your batter for like a min and it works.
btw, the ecu fuse is 15A, top left corner under the hood.
I also agree that it might be wired wrong or you may have the map sensor and IAT hooked up backwards. But then again, it would run like total ***.
Old Jan 20, 2004 | 03:22 PM
Nick7's Avatar
Default Re: check engine light won't go off... (BoostedSi)
I'd say he connected something wrong, or something ain't connected.
I had CEL when I forgot to connect temp. sensor on air intake... may be something similar...
Old Jan 20, 2004 | 04:19 PM
hawjdude's Avatar
Default Re: check engine light won't go off... (Nick7)
Hey my car does this too. Right when i turn the key the cel comes right on. So you guys are saying it could be wiring or map issues.
Old Jan 20, 2004 | 04:26 PM
ridnmyhonda's Avatar
Default Re: check engine light won't go off... (hawjdude)
My car did that too, i took out the lightbulb behind the dash..fixed the problem in no time
Old Jan 20, 2004 | 07:37 PM
turbosi03's Avatar
Default Re: check engine light won't go off... (ridnmyhonda)
ok thats cool, I know I'm not alone... Thanks for the info guys, I'll check my temp sensor, and go through the helms manual on map sensor wiring...
Old Jan 20, 2004 | 08:23 PM
aka010010
Guest
Posts: n/a
i had that problem too. my missing link was broken or something...is that possible??? anyways when u get that CEL does it put ur car into LIMP mode right away? it did to me, so i fixed it by getting hondata!
Old Jan 21, 2004 | 08:04 PM
turbosi03's Avatar
ha got it! a dumb one too... I went through the helms to check the map sensor which was fine... then went to check the IAT sensor (wish I did first) and it freakin wasn't there! I just have the piping from the intercooler with no sensor to plug the connector into.
I put a 20kohm resistor across the IAT connector pins to simulate 32 degrees (F), reset the ecu, and the engine light goes off... should I drive like that, or am I better off with the engine light on?
eg2tr
Jan 5, 2008 09:36 PM
EJ1 Type Slow
Jul 28, 2007 12:24 PM
g_dogg619
Oct 27, 2005 12:04 PM
