GSR Compression #'s
Old Jan 20, 2004 | 06:03 AM
speedy108's Avatar
Default GSR Compression #'s
I have a '99 GSR with a JRSC on it and the motor is stock with 73,000 miles on the clock. If I did a compression check on my motor, what kind of #'s should I see for my motor to be considered boost worthy?. I did a compression check on it about 5-6 months ago and saw 195-195-190-195, does this look right to you guys?. The supercharger is tuned with 440cc injectors and a Hondata s200, I plan on taking the charger off in about 3 weeks or so to go the turbo route. I just want to know what kind of comp #'s I should see before I put the turbo on the car.
Thanks.
Old Jan 20, 2004 | 06:08 AM
VTC_CiViC's Avatar
Default Re: GSR Compression #'s (speedy108)
Numbers are nearly identical, looks good
Old Jan 20, 2004 | 06:15 AM
speedy108's Avatar
Default Re: GSR Compression #'s (VTC_CiViC)
I just didn't know if these #'s are unusually low considering when I did a search people are coming up with #'s like 220-230 across the board.
Old Jan 20, 2004 | 06:48 AM
rtype11's Avatar
the manual says:
250rpm and WOT : nominal 270
minimum : 135
max variation : 28
your numbers are great so dont worry
Old Jan 20, 2004 | 07:05 AM
VTC_CiViC's Avatar
Default Re: GSR Compression #'s (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">the manual says:
minimum : 135
max variation : 28
your numbers are great so dont worry</TD></TR></TABLE>
Are you sure the manual says that? I don't recall the Helms reading that high, and I don't think ANYBODY has ever mentioned 270psi in a cylinder.
Old Jan 20, 2004 | 07:10 AM
rtype11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure the manual says that? I don't recall the Helms reading that high, and I don't think ANYBODY has ever mentioned 270psi in a cylinder.</TD></TR></TABLE>
yes i'M SURE that is also because nobody does the compression test right!
read 250rpm and WOT - wide open throttle! most of you just pull a spark plug and turn the car over on the starter a couple of revs, you will not get 250 rpm
also i used the acura service manual and not helms
Old Jan 20, 2004 | 07:33 AM
Chillinit's Avatar
numbers are good...i have the exact same motor and year...95 usdm gsr...190 across the board!
Old Jan 20, 2004 | 07:40 AM
VTC_CiViC's Avatar
also i used the acura service manual and not helms</TD></TR></TABLE>
Gee.. that's exactly how I do it, still never seen more than 220-ish psi
Old Jan 20, 2004 | 08:04 AM
speedy108's Avatar
Thanks for the help people.
Old Jan 20, 2004 | 12:56 PM
rtype11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Gee.. that's exactly how I do it, still never seen more than 220-ish psi </TD></TR></TABLE>
thats great dont worry about being at 270, look how large the variation honda allows for compression - 270 to 135, plus there is a difference when car is hot or cold etc.. thousand variables, if you have a daily driven high mileage motor with half an inch of coke on the pistons and dome you might get crazy high numbers also...
Old Jan 20, 2004 | 02:32 PM
madman604's Avatar
anything CLOSE to 210 is good IMO. 180 and lower is questionable. 270 and up is well unheard of to me.
Old Jan 20, 2004 | 04:41 PM
leadfoot78's Avatar
Default Re: (Turbo E)
don't worry about it, if you want to do a leak down test that will give you more info. When I first put my JDM GSR together it made 210-215psi, after 6 months of driving it make 230-235psi. The carbon buildup in the pistons and valves will make the compression higher and valves will seal better, also the # of cranks, type of cams, cam timing, engine temperature, and particular gauge will all make a difference.
Droolin
Nov 23, 2010 10:56 AM
Rtboy10
Sep 21, 2009 03:12 PM
hawaiieg6
Jul 15, 2009 08:57 AM
92integraVTECgsr
Jul 17, 2005 02:23 AM
siis2fast
Jun 16, 2003 11:09 AM
