look at this manifold
Old Jan 18, 2004 | 06:04 PM
CaptainMorgan's Avatar
Default look at this manifold
what do you guys think about the way this guys has the collector set up
http://cgi.ebay.com/ebaymotors...14049
Old Jan 18, 2004 | 06:21 PM
Silversupragirl's Avatar
Default Re: look at this manifold (doubler)
I'm not a "manifold" expert but to me it dosen't look bad to me at all *shrugs* As long as the wall are nice and thick and it flows, it should work fine
Old Jan 18, 2004 | 06:43 PM
10seceg's Avatar
looks pretty good to me...but its only for internal wastgate turbos...
Old Jan 18, 2004 | 06:51 PM
twkdCD595's Avatar
Default Re: (10seceg)
looks pretty good, but the internal wastegate sucks.
Old Jan 18, 2004 | 09:11 PM
redboost10's Avatar
Default Re: (twkdCD595)
you can cut a 1 1/2" hole outta that collector with a holesaw and make it an external wg manifold
Old Jan 18, 2004 | 09:47 PM
b18b1hmtlove's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">looks pretty good, but the internal wastegate sucks. </TD></TR></TABLE>
Such a myth. Try porting out the hole for the internal gate and then say internal gates suck......
Basically the internal gate is made to work with more back pressure because the smaller exhaust units that are found on stock cars. Less backpressure, the unit wont work properly. Just port the hole a few mm and it will perform better....
Stupid comments like this plague this site.
Old Jan 18, 2004 | 09:52 PM
rjardy's Avatar
Default Re: (b18b1hmtlove)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">
Stupid comments like this plague this site.</TD></TR></TABLE>
true but its still not a good solution for boost metering on a high PSI application. But generally, its fine for street cars.
Rob
Old Jan 18, 2004 | 10:13 PM
Well obviously its not a solution if you are looking for a lot of power, but most people on this site regardless of what they say, are just riding around in a 300whp or less street car and an internally gated T3 would be just fine for their application.
Old Jan 18, 2004 | 10:45 PM
Ri5e's Avatar
Collector looks funky
Old Jan 18, 2004 | 11:34 PM
twkdCD595's Avatar
I doubt my 60-1 would work well with an internal wastegate at higher boost.
btw I have no doubt the ported internal gates can do just fine for most applications with small-mid sized unit and decent power levels. I seen some local dsms at just under 300whp using a unit modified like that (also had been clipped or something too).
Old Jan 19, 2004 | 03:49 AM
hpfsi's Avatar
Default Re: look at this manifold (silversupragirl)
That is a sorry excuse for what you would call a collector... a pipe transition is by no means a merge collector.
fastazzf22
Jun 4, 2008 04:18 AM
manifoldmiketyson
Welding / Fabrication
21
Feb 22, 2008 05:48 PM
RACEPAK
Feb 17, 2005 03:16 PM
rusteds2k
Jan 30, 2005 09:21 AM
Egone
Feb 6, 2004 02:28 PM
