DRAG III Questions about Precision and Inline
Old Jan 18, 2004 | 05:50 AM
1SlowSi's Avatar
Default DRAG III Questions about Precision and Inline
I searched through 200 posts and couldnt find what i was looking for. I am getting the Drag III Kit but instead im going to be using the Inline Pro Manifold, and the Precision SC34 Turbo. Are there going to be ANY clearance issues with either of these upgrades? The 38mm fitting on the Inline Pro? Shaving off the block? Will the IC piping that comes with the kit fit right up to this new setup? If not what will i have to do. And last of all, can i keep my AC and stock fan?
Would you suggest any other manifold thats as nice as this one? Any pics of the inline pro manifold installed? Thanks guys.
Ohh BTW, its for a B16A2, but im going to be using a B18B or C one day, being that it all bolts up to the head, i shouldnt have problems right?
Old Jan 18, 2004 | 06:04 AM
Boostage's Avatar
Default Re: DRAG III Questions about Precision and Inline (1SlowSi)
https://honda-tech.com/zerothread?id=736947
Old Jan 18, 2004 | 06:42 AM
1SlowSi's Avatar
Default Re: DRAG III Questions about Precision and Inline (Boostage)
Wow, thats nice... in your opinion is SFR really that nice... that one to be exact? And also, i did find some stuff about inline pro manifolds, and it seems to be that EVERYONE has a problem and has to grind down the block alot. I dont want to grind anything down. Now, with a new manifold (depending on which one) and the Precision SC34 turbo, what problems would i run into. Will i have problems with the downpipe, dump tube or IC piping?
Old Jan 18, 2004 | 09:17 AM
blueturbo4door's Avatar
on the b16a2 i believe that you will have to shave the block a little bit. i did a test fit of my turbo in my car this past week. i have the inline pro manifold with the sc61. i had to shave about 0.75" away. not too big of a deal. also i dont know how close the dump tube will be to the ac condenser because i didnt have mine in. lastly all of your intercooler piping will line up. and yes you can run a 2.5 inch downpipe and retain ac. im running a 3" w/ ac but its a lot of work
Old Jan 19, 2004 | 07:52 PM
1SlowSi's Avatar
Default Re: DRAG III Questions about Precision and Inline (99n00sis)
Did you have to grind away on the webbing or the actual block. that gets kinda scary! haha, what kinda work you talking about when trying to fit in the rest of it?
Old Jan 19, 2004 | 10:18 PM
11psiTurboSI's Avatar
When I got my Precision SC50 and Drag manifold I had to shave alittle webbing off the block... its no big deal you can see how much you grind off!
Old Jan 19, 2004 | 10:41 PM
1SlowSi's Avatar
Default Re: DRAG III Questions about Precision and Inline (9psiTurboSI)
Yeah i hear that. I will be using the SC34 but i think im going with the Inline Pro manifold. I have heard lots of problems with this setup though. what do you think?
Old Jan 20, 2004 | 01:42 AM
MaxSterling's Avatar
correct me if i'm wrong but drag downpipe will not fit correct when used with inlinepro manifold
Old Jan 20, 2004 | 01:57 AM
1SlowSi's Avatar
Default Re: DRAG III Questions about Precision and Inline (MaxSterling)
thats right. it will only work with the drag manifold.
nytosc
Mar 7, 2009 06:22 AM
civteck84
Jan 23, 2006 08:22 AM
egVTI
Dec 19, 2005 08:24 AM
Nextelbuddy
Apr 10, 2004 03:05 PM
pub
Jul 16, 2002 06:54 PM
