Gotta Problem!!!!!
Old Jan 18, 2004 | 02:49 PM
FOrSfEd's Avatar
Default Gotta Problem!!!!!
For some reason my car idel's up and up and down sometimes all the time and it won't stop. Anyone know how to fix this.
Thanks alot
Lee
Old Jan 18, 2004 | 02:55 PM
FOrSfEd's Avatar
Default Re: Gotta Problem!!!!! (FOrSfEd)
damn the place moves fast.
Old Jan 18, 2004 | 03:22 PM
grndcont's Avatar
probly have to be more specific. any cel's?
Old Jan 18, 2004 | 03:26 PM
gsrcivict's Avatar
to lee wassup? hey man my car was doing the same thing and it was the intake manifold gasket. I sprayed some carb cleaner around it while it was idleing and it shut the car off. I replaced the gasket and bam! problem fixed. let me know man you can gimmie a call if you want. peace!
Gabe
Old Jan 18, 2004 | 03:31 PM
rtype11's Avatar
check for sources of vacuum leaks first like the TB gasket as above mentioned, then IAC/IAB/FIT - or maybe just a lumpy camshaft. also check your car isnt in limp mode, if it is reset the ECU
Old Jan 18, 2004 | 03:32 PM
FastEK9's Avatar
it is most likely your fast idler. it islocated underneith your throttle body. has 2 coolant hoses comin outta it. the is a cover on the firewall side of the fastidler held on with (2) 8mm bolds remove the cover and turn the (white) plastic part back into the housing. and pput cover back on.
Old Jan 18, 2004 | 03:50 PM
FOrSfEd's Avatar
Default Re: (FastEK9)
thanks alot fast. I'll check it out tomorrow.
Old Jan 18, 2004 | 03:54 PM
99blackcivicSi's Avatar
Default Re: (FOrSfEd)
pull off the IAC motor and clean it it is probably jet black squirt it with break clean till the screen is clear agian that might help a lot.
Old Jan 18, 2004 | 04:50 PM
xenocron's Avatar
Default Re: (99blackcivicSi)
Make sure you reset the ECU in either case...honda ecu's store wierd ilde issues in memory. After resetting the ECU, start the car and dont touch anything until it completely warms up (two cycles or the Fan).
Old Jan 18, 2004 | 05:54 PM
boosted_dc2's Avatar
Default Re: (xenocron)
sometimes coolant issues can cause this as well. check your oolant level and your system for leaks.
Landon
Old Jan 18, 2004 | 06:16 PM
turbotypeR@SPEC's Avatar
25 Year Member
did you change the coolant lately?the most common cause i have seen for this is air in the water.when you refill it,it needs to run for a very long time with the cap off to let the thermostat open and for all of the air to get out.if you did not do that,you can probably just add some water when it is cooled off completely.just wait until the next morning and add as much as it will take
Old Jan 18, 2004 | 06:17 PM
FOrSfEd's Avatar
Default Re: Gotta Problem!!!!! (turbotypeR)
Thanks a lot Danny. I'll give it a try tomorrow.
NFM_Dm
Mar 20, 2010 02:27 PM
nineohnine
15
May 30, 2009 01:21 PM
StupidSlowRSX
Jan 15, 2007 05:15 AM
joecivic93
Jan 3, 2004 10:25 PM
amit
Nov 26, 2002 08:18 AM
