SUSPENSION
Old Jan 22, 2002 | 07:41 PM
SYDNEYSIDER's Avatar
Default SUSPENSION
Hey guys, I dont know a good deal about suspension. I did a search but I wanted someone to explain. Im getting Apex springs, koni yellows and ITR rear sway bar with the bsq kit. I saw a lot of posts with their set up including rear upper and lower tie bar and front upper and lower tie bar.
What are tie bars and what do they look like and what benefits??
TIA
Old Jan 22, 2002 | 07:44 PM
Chris's Avatar
Default Re: SUSPENSION (GS-R_ocks)
They go in between the shock towers.. they improve chassis rigidity.
Old Jan 22, 2002 | 08:07 PM
Default Re: SUSPENSION (Chris)
are they worthwhile to buy????what about strut bars???im kinda lost...
Anyway, im just planning on a good street suspension....just dont want too much body roll......Im not going to autox so is it worthwhile for me buying it?
ta
Old Jan 22, 2002 | 08:53 PM
cmon guys.....what is a strut bar???I want to now if they are any good.....what about the bushing kit?????should I buy that too???what difference would it make??...
Old Jan 23, 2002 | 12:36 AM
2005 TSX's Avatar
Default GS-R_ocks
Here are some pictures of my 2001 GS-R with a U.S. Type-R Front Strut Bar...
Here are some pictures of my 2001 GS-R with the optional Japanese Type-R Rear Strut Bar...
Again, these bars allow for greater rigidity throughout the chasis.
More pictures of the front bar...http://www.imagestation.com/album/?id=4292317833
More pictures of the rear bar...http://www.imagestation.com/album/?id=4292105437
[Modified by 2001 Integra GSR, 1:36 AM 1/23/2002]
Old Jan 23, 2002 | 09:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: GS-R_ocks (2001 Integra GSR)
How much was that ITR rear bar, and where did you get it?
Old Jan 23, 2002 | 09:48 AM
HaUTSaauce's Avatar
New User
nice pics
Old Jan 23, 2002 | 11:44 AM
2005 TSX's Avatar
Default PatrickGSR94
I don't remember off hand how much the bar was, but it was $175+ for sure. I got it from Mike over at ipsracing.com. Prices can fluctuate, so you just have to ask him. You can e-mail, call, or Instant Message him...https://honda-tech.com/zerouser?cmd=viewprofile&id=4039. He goes by the name TypeRmsm on this board.
IPSRacing.com
Mike - Owner
1(866)IPS-RCNG
M-F 10AM-6PM EST
Old Jan 23, 2002 | 12:00 PM
MechE00's Avatar
For street suspension, the rear strut tower bar (aka upper tie bar) and lower tie bar are not really important. When you get to higher spring rates than are comfortable for the street, the chassis starts becoming "soft" relative to the stiffer spring rates, and chassis flex starts becoming more of an issue.
I've read people's testimonials about how much improvement they found when they put their tower bars in, and honestly I believe it to be mostly placebo effect.
The GS-R already has a front strut tower bar (due to the extra mass of the engine up fron, the reinforcement makes more of a difference there). If you bought a swaybar/tiebar combo for the back, I'd say great.. but if you bought the ITR/BSQ out back, I wouldn't worry about any more bars.
If you want them, like the look of them, or whatever, go for it. But for street application, the springs, shocks and sway bar are going to dominate the car's behavior. (and I believe you'll be happy with it)
They certainly don't hurt anything except maybe trunk usability, a tiny bit of ground or muffler clearance, and your wallet.
Old Jan 23, 2002 | 12:45 PM
Default Re: SUSPENSION (MechE00)
Great. Thanks. I like how the rear strut tower bars look, but then again im not doing autox so i'll just have the type r rear sway bars.
Old Jan 23, 2002 | 02:54 PM
strils's Avatar
i have the USDM front ITR Strut bar and the rear JDM ITR Strut bar and i love em, if you want to see pics click on Mods below
Old Jan 23, 2002 | 02:58 PM
Cramerox's Avatar
Default Re: PatrickGSR94 (2001 Integra GSR)
hey 2001 INTEGRA GSR.
How did you make those cuts on the plastic so clean? on the Rear top struts? NICE
Old Jan 23, 2002 | 03:02 PM
strils's Avatar
Default Re: PatrickGSR94 (Cramerox)
the strut bar comes with some rubber pieces to go around the lip to make it look nice and i cut my holes for the bar to go through with a dremel
Old Jan 23, 2002 | 03:11 PM
MattG's Avatar
New User
QUOTE]
What are tie bars and what do they look like and what benefits??[/QUOTE]
The rear tie bar will control flex between the points the lower control arms connect to the frame. The comptech tie bar also prevents tear out with a beefier sway bar.The attached link has some good pics.
http://www.comptechusa.com/instructions/ins078.pdf
Old Jan 23, 2002 | 04:32 PM
2005 TSX's Avatar
Default Cramerox
strils: the strut bar comes with some rubber pieces to go around the lip to make it look nice and i cut my holes for the bar to go through with a dremel
Cramerox, when you purchase the kit, it comes with a template and instructions to cut out the holes in the strut covers. It also comes with the precut rubber pieces to go over and around the rough edge that has been cut. I used a circle template for my design, and a Jigsaw with a special metal blade designed to cut plastic. If you would like more detail, or information, just drop me a line and I will be more than happy to help out.
Slava.
Jan 26, 2004 02:25 PM
f22suzuka
Jul 29, 2003 10:53 AM
mickey513
Apr 30, 2003 03:31 AM
2000Accord5sp
Oct 17, 2002 04:11 AM
2000Accord5sp
Oct 16, 2002 09:36 PM
