Project LS Dyno
Old Jan 22, 2002 | 08:47 AM
ATYPR's Avatar
Default Project LS Dyno
I took project LS to the dyno this weekend to see what it's doing at the wheels, befoe tuning and the ECU is rechipped.
It put down 153.3hp and 131.4 lb-ft! That's all motor with no tuning and stock fuel cut. I can't wait to see 8000rpm.
Old Jan 22, 2002 | 09:37 AM
GSG2's Avatar
Default Re: Project LS Dyno (FUCATYPR)
what are the mods u did to the LS?
Old Jan 22, 2002 | 10:43 AM
ATYPR's Avatar
Default Re: Project LS Dyno (jobau)
Pistons, cams, ARP rod bolts, and modified oil pump.
Old Jan 22, 2002 | 10:51 AM
Mr. Thunderlips's Avatar
if you dont mind me asking, which pistons and cams...what are the specs...and are you running a straight pipe...intake, header, etc, etc...
Old Jan 22, 2002 | 10:55 AM
teg92's Avatar
Default Re: Project LS Dyno (Slo_Teg)
any porting?
Old Jan 22, 2002 | 11:15 AM
ATYPR's Avatar
I'm keeping the pistons a secret for now but I will tell you that we are using Crower 403's, DC 4-1 header, cheap intake, and HKS exhaust. The cat. is still on the car and it has no head work.
Can someone post the chart if I send it to them?
Old Jan 22, 2002 | 11:24 AM
Westrock2000's Avatar
BA
-for Bad ***!
Old Jan 22, 2002 | 11:27 AM
HX_Guy's Avatar
http://www.orbit3d.com/
Old Jan 22, 2002 | 11:32 AM
Default Re: Project LS Dyno (HX_Guy)
As seen on the main page of http://www.orbit3d.com/
*NOTE: THE SITE HAS NOW CHANGED TO ACCOMIDATE GAY MSG BOARDS*
Thats just super
(HX_Guy is it your server!?!?)
[Modified by Westrock2000, 8:33 PM 1/22/2002]
Old Jan 22, 2002 | 12:39 PM
ATYPR's Avatar
Default Re: Project LS Dyno (Westrock2000)
Old Jan 22, 2002 | 12:54 PM
Project X's Avatar
With only these mods, that is very impressive!
This is only what I've gotten from the following mods:
reprog. OBD-I ECU
Crower 62403 cams/springs/retainers
milled cyl. head (0.015")
3-angle valve job
AEM CAI (2.5")
64mm bored TB/matched IM
DC 4-2-1 headers
DC 2.25" exhaust
AEM cam gears (0,0)
AEM pulleys (useless)
Max. HP = 143.5 hp @ 6500 rpm
Max. TQ = 119.6 lbs-ft @ 5300 rpm
Old Jan 22, 2002 | 01:25 PM
mamaboy's Avatar
cmon what pistons are you using...it could save my life....
Crower 403's...retainers and valve springs?
anything done to the TB and Intake Manifold????
new fuel rail, FPR????
What do you have Campulleys dialed into????
What Campulleys do you have?..if you have any...???
any milling????
what connecting rods along with your pistons?????
SAVE ME SHARE THE KNOWLEDGE!!!!!!!
Old Jan 22, 2002 | 01:49 PM
ATYPR's Avatar
Default Re: Project LS Dyno (Project X)
reprog. OBD-I ECU
3-angle valve job
AEM CAI (2.5")
DC 4-2-1 headers
DC 2.25" exhaust
AEM cam gears (0,0)
The other plot is a stock LS with cam gears, exhaust, and intake. The customer may go with the 404's if we don't see the numbers we want.
[Modified by FUCATYPR, 10:50 PM 1/22/2002]
Old Jan 22, 2002 | 02:02 PM
non-VTEC's Avatar
good numbers.............must be some pretty high compression pistions
Old Jan 22, 2002 | 03:18 PM
ATYPR's Avatar
Default Re: Project LS Dyno (mamaboy)
any milling????
It does have retainers and valve springs but the TB, intake manifold, fuel rail, injectors, and FPR are all stock.
Old Jan 22, 2002 | 05:38 PM
Mr. Softee's Avatar
Thats just super
no that would be mine.... i coded that in mysql / php... dont even try to give val credit!
Old Jan 26, 2002 | 10:30 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: Project LS Dyno (94goldjungsr)
I raced this car b4 this build and it was fast then too. I cant wait to see this out! Might have a after tha build follow up post by me!!!
2LEM1
13
Apr 25, 2008 04:25 PM
integranator
Dec 17, 2007 10:37 PM
sneakypete
Jul 17, 2005 06:31 PM
rex_racer728
May 6, 2005 12:09 AM
SpoonFedHatch
Apr 7, 2003 08:45 PM
