Comptech Icebox
There is no knock off version of the icebox. It is a very goo intake ( so far no reported case of hydrlocking) plan on paying 160- 200 clams for one
Also where can I get...a good knockoff version.
I made one by BSQ's instructions. Not sure how well it works with a paper filter (no K&N in there yet
), though. When I drove around w/ no piping at all below the airbox, it was LOUD! Now even w/ just a short pipe that ends behind the turn signal, it's not nearly as loud.
For those people that own the Comptech ice box and are using your stock arm, does the rubber arm touch the a/c line underneath it?
I would highly recomend the Icebox. After driving in heavy rains and going through some running water by a curb everything was bone dry inside. Plus it has a great sound when the secondaries open.
No, Everything is really close but nothing rubs. My filter is somewhat off center. i had to rotate the filter until it fit well with the angled platic piece that fits into the stock intake tube.
[Modified by reVVin, 9:43 PM 1/22/2002]
even with the icebox knockoff, since the intake pipe is soo low i'm sitll scared of hyrdolocking......
Hey Bret,
I'm assuming your turn signal is still installed? See, I was going to make an tubing extension for my box based on your instructions. But I was wondering A) How airflow into the inlet was with the turn signal installed, cause I drive mine every day and would need to leave the signal alone and B) How to work around that big piece of plastic if I were to leave it installed (the back of the signal housing really is pretty huge).
I'd about decided to modify the tubing length to pull air from the grille, probably from where the OEM fog lights would be. Just cut out the plastic insert and somehow harness the tubing in. But then it got cold out and I didn't want to spend any more time outside than I had to. So it's looking llike a springs project (when SCCA gets started back up, anyway). The height is roughly the same as the signal mounting, by the way. I was also going to install a piece of screen (probably just wire window screen) to keep the bugs and large objects out. Think that would block too much air?
Any thoughts?
Any thoughts?
BSQ, I don't suppose you ever dyno'd your DIY icebox against the stock one to see how it compared to Comptech's did you?
I'd be very interested to see the results if you did..
Hey Bret,
I was wondering A) How airflow into the inlet was with the turn signal installed, cause I drive mine every day and would need to leave the signal alone and?
bobmugen
Northern California (Sales)
69
May 31, 2009 10:14 AM
