Which Replacement Radiator?
Old Jan 22, 2002 | 03:28 PM
joeg26er's Avatar
Default Which Replacement Radiator?
My radiator has cracks in the plastic upper tank. It loses almost half the coolant in a few weeks.
I don't want to spend more than $200 including the shipping costs.
What radiator should I get and from where?
My local sources can't get it any cheaper than $250+tax.
I see on absoluteradiator.com they have an "all metal" brass/copper direct replacement for $177.23 shipped.
I was worried that the brass and copper might react with the aluminum and other materials of the engine and
cause some accelerated corrosion or corrosion products.
What have you guys bought? Any other sources? Cheaper ? Better?
Thanks in advance for the help. I need to replace this radiator before Feb 7th...gotta road trip.
Old Jan 22, 2002 | 03:32 PM
Westrock2000's Avatar
Default Re: Which Replacement Radiator? (joeg26er)
I got an all metal radiator when mine cracked. it was $150 locally. I'd say do it, I've had mine for a year and haven't had any leaks or nothing.
Old Jan 22, 2002 | 04:01 PM
BoM's Avatar
BoM
Default Re: Which Replacement Radiator? (Westrock2000)
http://www.radiators.com/
get a kuyo replacement.
quick delivery
Old Jan 22, 2002 | 05:10 PM
joeg26er's Avatar
Westrock - where did you get your radiator and exactly what is it called and what is it made of?
More info would be great - thanks
Old Jan 22, 2002 | 05:12 PM
joeg26er's Avatar
Default Koyo Radiator too $$$ (BoM)
Yikes0- I do not want to spend more than $200
That Koyo is $458!! Aaagh!
Thanks though - i found a fluidyne for $315...but still too expensive for my purposes.
Old Jan 22, 2002 | 07:37 PM
MattG's Avatar
New User
I believe the stock ITR radiator is all AL. You can try getting one as a replacement. I have heard people say they bolt right in with little to no adjustment. I would check it out though.
Old Jan 22, 2002 | 08:05 PM
BoM's Avatar
BoM
Default Re: Which Replacement Radiator? (MattG)
get the oem replacement from the site, its like a 100 bucks...or get a civic one
Old Jan 22, 2002 | 08:08 PM
OneThirtyEight's Avatar
Default Re: Which Replacement Radiator? (BoM)
I got a fluidyne. Its great!
[Modified by 97blackteg, 12:08 AM 1/23/2002]
Old Jan 22, 2002 | 08:28 PM
Big Ed's Avatar
Default Re: Which Replacement Radiator? (97blackteg)
I replaced mine with a Fluidyne as well, no complaints.
Old Jan 22, 2002 | 10:18 PM
Default Re: Which Replacement Radiator? (Big Ed)
and at night, when people shine thier hedlights in there, it kinda looks like an intercooler. Im so desperate for a turbo
Old Jan 23, 2002 | 05:25 AM
joeg26er's Avatar
Default Fluidyne TOO Expensive...
I don't want to spend more than $200 shipped.
What is the best replacement radiator for my '94 GSR AND where can I get it?
Thanks in advance
Old Jan 23, 2002 | 05:27 AM
joeg26er's Avatar
Default Civic radiator?
Isn't that Civic radiator going to be too small?
I don't want to mess with funky mounting.
I think the ITR radiators are selling for over $200- not within the budget.
Old Jan 23, 2002 | 06:32 AM
BSQ's Avatar
BSQ
I just wanted to let everyone know that the Type-R radiator IS NOT all aluminum. The core is aluminum, but the top and bottom caps are plastic, so it can also have the same leaking problems. The only difference the Type-R radiator has is it is slightly lighter in weight (this was confirmed by Mike K. who posts on the Type-R forum and works at an Acura parts department).
Old Jan 23, 2002 | 07:00 AM
BSQ's Avatar
BSQ
Default Re: Fluidyne TOO Expensive... (joeg26er)
I was in the exact same situation as you about 4 month ago. Yes, it would have been nice to buy a nice all-aluminum race radiator like the Fluidyn or Koyo, but in the end I just could not justify the cost ($315+ for the radiator and $80 for the thin depth radiator fans, so approx. $400+). Plus, my stock radiator was having no problems cooling my car (even when driving on the track for 30-minutes in 85-90 degree weather).
In the end, I finally decide to buy an aftermarket OEM Equivalent Replacement Radiator (copper & brass) for http://www.radiators.com for $158 shipped. I placed my order in the morning and I received the radiator the next day (they have several warehouses across the country). The radiator fits just like the stock radiator and it has a lifetime warranty. I haven't noticed any difference compared to stock since I installed it. HTH
[Modified by BSQ, 8:01 AM 1/23/2002]
Old Jan 23, 2002 | 07:39 AM
madchiller's Avatar
Premium Member
25 Year Member
i picked an OEM replacement for $135 including tax and installed it in like 20 minutes after the car cooled down. might want to consider replacing your upper and lower radiator hoses while you are at it!
Old Jan 23, 2002 | 07:48 AM
BoM's Avatar
BoM
Default Re: Fluidyne TOO Expensive... (FuknGSR)
me and my friend used an EF civic radiator for his hybrid
he has an H22. it stays cool
using that smaller radiator along with thermostat and hipressure cap
will max out your cooling system. If you have a new radiator i think its more
than enough. Maybe a new water pump along with it.
if your thinking about turbo or anything in the future that requires room
carefully choose one.
Old Jan 23, 2002 | 09:10 AM
Geeboy's Avatar
Default Re: Fluidyne TOO Expensive... (BoM)
I'm having a problem with my radiator too... I keep smelling coolant and after 1 drive, my coolant bottle empties out. Anyone know what's wrong with it?
Old Jan 23, 2002 | 09:25 AM
ndustryalGSR's Avatar
Default Re: Fluidyne TOO Expensive... (Geeboy)
You can also get all-metal (copper and brass) radiators from Performance Radiator. They have retail stores all around the country. I found one locally, and they even charged less than the website indicates -- only ~$140.
Old Jan 23, 2002 | 09:31 AM
BoM's Avatar
BoM
u might have a leak somewhere, where u park check if theres any coolant around.
if not u might have to get a leakdown test to see if the internals have leaks.
how many miles is your car?
how is the temperature doing?
another problem might be a blown head gasket...which will destroy you almost
everything...cylinders ect....try doing a search about head gasket or coolant.
Old Jan 23, 2002 | 09:40 AM
BSQ's Avatar
BSQ
This is the same thing that happened to me. The crack in the radiator was so thin and long that the coolant would literally evaporate on the hot radiator. So it wasn't really evident at first where the radiator was leaking. But as time went on the radiator started to show signs of leaking. My crack on the radiator was on the front side underneath a rubber/foam gasket which is attached to the plastic tank. I wasn't 100% sure where the radiator was leaking until I removed it from the car and that is when I found the thin long crack.
Old Jan 23, 2002 | 09:46 AM
HaUTSaauce's Avatar
New User
FLUIDYNE
Old Jan 23, 2002 | 10:42 AM
Geeboy's Avatar
Default Re: Which Replacement Radiator? (HaUTSaauce)
How do they just crack? My car's a 95 GS-R, is it about time to replace it, huh.
Old Jan 23, 2002 | 11:53 AM
BoM's Avatar
BoM
Default Re: Which Replacement Radiator? (Geeboy)
check to see if its cracked by inspecting it.
or drain it and run a hose through it.
gsr cooling systems are top notch, HONDA cooling systems are
very good.
Old Jan 23, 2002 | 11:54 AM
BSQ's Avatar
BSQ
The upper radiator cap is plastic. With age and heat the plastic weakens and finally cracks. It seems like in the last 6 months there has been a threads on this topic.
1996hondaaccord
Aug 11, 2008 03:11 PM
Wiggler
Feb 21, 2006 08:10 PM
eastsideATX
Jul 6, 2005 02:56 PM
stickeyfingaz
Dec 21, 2004 11:26 AM
techboy3244
Jan 20, 2004 04:00 PM
