problem getting it into reverse
Old Jan 19, 2002 | 05:32 PM
comptechgsr's Avatar
Default problem getting it into reverse
i tried the "Neutral, then a gear like 4th or 3rd, then Reverse and it still doesnt work....
however, i tried laying it gently into reverse, then releasing the clutch a lil (not pushed to the floor) and it goes in?
huh
Old Jan 19, 2002 | 08:34 PM
eh-D's Avatar
Default Re: problem getting it into reverse (comptechgsr)
Sometimes I have to let up on the clutch slightly to get into reverse, actually I have had to do it in multiple cars(and one truck), I assume it's normal.
Old Jan 20, 2002 | 04:10 AM
vertius's Avatar
My car has a bad time with reverse. If I start my car, it will go into reverse no problem. As soon as I pull the car out of the garage, close the door, and pull out of the driveway, it is almost impossible to get into reverse. I sometimes get stuck at gas stations when someone pulls in front of me. I will sit there for a couple of minutes trying to jam it in.
Old Jan 20, 2002 | 06:33 AM
Dirty GS-R's Avatar
New User
Default Re: problem getting it into reverse (vertius)
It happened with my gsr tranny and even now with my ITR tranny. Sometimes it takes a couple of tries before going into reverse.
Old Jan 20, 2002 | 06:46 AM
IC x Prince's Avatar
New User
Default Re: problem getting it into reverse (2K1 GS-R)
the same thing happened to me...an reverse lights wouldnt go on after awhile...my friend at Honda fixed it...changed the tranny fluid w/ honda mtf not synthetic...and it works perfect now.....my tranny fluid was old and dirty...hope that helps... [
Old Jan 20, 2002 | 07:24 AM
maggsgsr's Avatar
Default Re: problem getting it into reverse (UltraGSR)
Same problem,put it in nutr,let off the clutch then pu right back in and go into reverse
Old Jan 20, 2002 | 09:19 AM
MattG's Avatar
New User
I have had that happen with every manual car I have ever driven.
Old Jan 20, 2002 | 12:11 PM
Homer_Simpson's Avatar
Default Re: problem getting it into reverse (MattG)
try puttin it into first then back to into neutral then reverse.... Works for me!
Will-
Old Jan 24, 2002 | 06:28 AM
WOTTEG's Avatar
I agree with *****rAcEr.
First --> Nuetral --> Reverse usually works for me.
Never "Cram" it though, ouch!
The Reverse synchro is the culprit.
Try double-clutching to ensure that the synchro and the engine are spinning at the same speed.
Double-clutching isn't only for +6,000 rpm racing.
Old Jan 24, 2002 | 06:45 AM
fiebru1119's Avatar
Default Re: problem getting it into reverse (WOTTEG)
my car does the same thing.. but i have a bad release bearing on the clutch which is gonna get replaced this wknd.. other than that, my other car did that every once in a while so i dont think ur in trouble
Old Jan 24, 2002 | 06:57 AM
samagon's Avatar
just putting it into a different gear and then trying for reverse doesn't work all the time.
every gear except for reverse (incl. first) has synchros, so if it isn't going into reverse at all, you have to either roll the car (so it rolls the lay shaft) or roll the input shaft. so put it into neutral, release clutch then you can put it into reverse. or if you are rolling down a hill a little it will slip in as well.
ek_b16
Dec 10, 2006 10:19 PM
JDM_B18C5
Oct 4, 2004 12:29 PM
BlueIntegraBoy
Jul 25, 2004 11:57 AM
JdmFront619
Nov 7, 2003 03:03 PM
