G3 ABS issues.....
Old May 22, 2002 | 12:45 PM
Dirt's Avatar
Default G3 ABS issues.....
Delear gave me code 4-8 from my ABS control box (bad left rear ABS wheel sensor). Cleaned all 4 sensors and still I have an ABS light.
Any info and/or insight about the code and/or bad sensors is much appreciated. I have an online G2 Helms, but wonder if the ABS system is unchanged for my 1994 GS-R.
For the full report, go here..... https://honda-tech.com/zerothread?id=190559
I realize I should just replace it instead of posting this, but just looking for any insight on something I can try to do before then. Thanks again.
[Modified by Velvet Jones, 1:46 PM 5/22/2002]
Old May 22, 2002 | 01:26 PM
CZ-75's Avatar
Default Re: G3 ABS issues..... (Velvet Jones)
Is the wiring to and from the sensor hot?
could be that a wire, connector is loose or broken.
Old May 22, 2002 | 01:50 PM
Dirt's Avatar
Default Re: G3 ABS issues..... (CZ-75)
It's possible and I haven't looked into that, but the ABS light is not on all the time. When the ABS light is off, the ABS pulsates and works like it should. But I guess that could be a poor (not quite broken) connection.
Anyone with a Helms care to check info about ABS codes and specifically 4-8? Thanks.
Old Jun 5, 2002 | 05:42 AM
GM2000ITR's Avatar
New User
Aaron, let me know if you need another ABS module....I will be pulling the one from my ITR along with the prop. valve, lines, master cylinder & booster. All of this will be for sale. -Greg
Old Jun 5, 2002 | 06:33 AM
junglistgsr's Avatar
Default Re: G3 ABS issues..... (GM2000ITR)
how much are you selling it for?
Old Jun 5, 2002 | 01:50 PM
Dirt's Avatar
I need your two rear wheel sensors. Please let me know if you can remove them for me. Thanks. -Aaron
Old Jun 6, 2002 | 04:46 AM
GM2000ITR's Avatar
New User
Sorry Aaron, but I don't have the wheel sensors. All that I have left is the module, line, boster, M.C. and prop. valve. -Greg
Old Jun 6, 2002 | 05:16 AM
GM2000ITR's Avatar
New User
*Update*......Sorry guys, but I've decided not to sell the booster. Everything else is for sale. First $450 takes the lot! Keep in mid that the ITR ABS module alone is worth much more than that!! I'm selling it all dirt cheap simply because I need extra cash right now (my wife just changed professions and hasm't brought home a dime in about 2 months! Post if you're interested or email me at gregmendez@swfla.rr.com
[Modified by GM2000ITR, 7:03 AM 6/6/2002]
jrmullins85
Sep 24, 2015 05:40 AM
Whatislove
Honda Civic (2001 - 2005)
16
Jun 14, 2009 01:53 PM
DubFat
Apr 15, 2005 10:04 PM
Shaun92lude
Dec 8, 2004 07:11 AM
