ITR Conversion
Old May 19, 2002 | 09:58 PM
ITRmike98's Avatar
Default ITR Conversion
Has anyone ever put a B18C5 (Integra Typr R) engine, tranny, ecu... into a GSR or other model integras? I have a 1997 GSR and i want to do this. Are there any necessary modifications to the ECU or the wiring that need to be done, or will i run into any other disasters in the process? Also, will my ABS system be compatible with the ECU also because i know that it is different.
Thanks for your knowledge,
Mike
Old May 19, 2002 | 10:07 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: ITR Conversion (gsr mike02)
IMO just build your engine - more for the money. there's nothign wrong with a B18C1
Old May 19, 2002 | 10:13 PM
qtiger's Avatar
Not worth it, just build what you've got.
Old May 19, 2002 | 10:19 PM
ITRmike98's Avatar
Default Re: ITR Conversion (qtiger)
A) Im getting all of the parts new
B) Im getting it for cheap
C) I can do all of the work myself and sell my old engine, trans...
D) I need a trans. rebuild soon anyways
E) A lot more horsepower
F) Mods like cams and high comp. pistons and a new intake manifold are just as expensive if not more
Old May 20, 2002 | 11:30 AM
maggsgsr's Avatar
The complete swap is not a bad idea.Stronger motor,and those short gears with lsd.
Old May 20, 2002 | 11:41 AM
reefer_bob's Avatar
Default Re: ITR Conversion (maggsgsr)
If you can do the work yourself, just yank your engine out, take it up to 84mm bore, get a good head P&P, match the combustion chambers, Skunk II maifold throw some 12:1 pistons in there, get some good bumpsticks. That's a hell of a lot cheaper than even a 'cheap' ITR engine, and you'll be easily over 200whp.
Old May 20, 2002 | 11:43 AM
t's Avatar
t
A) It will cost A LOT more than just building up your GsR, especially if all the parts are new (And if you are going to get it part by part, it will be cheaper to just buy a Spoon or Jun built motor)
B)Cheap is still going to cost a lot (You can reuse your GsR block with ITR pistons, and buy the Type R head, manifold,...etc.)
C)If you have the knowledge to do it yourself, build up your GsR (High comp pistons, rods, ported head, manifold,...etc.)
D)Trans rebuild with higher final drive and better LSD than ITR
E)Not really (GsR with Intake header exhaust can get real close to ITR power)
F)Buying a new complete ITR motor with tranny and ecu will cost way more than a rebuild; as the ITR crate motor and Longblock are no longer available from Honda; you will need to buy each piece separately;shortblock,head,tranny, manifold,...etc.
Old May 20, 2002 | 12:37 PM
ITRmike98's Avatar
Default Re: ITR Conversion (t)
Will somebody just answer my ORIGINAL question?
i will be getting the parts for $4000 . I can sell my stuff for around $2000.
Thats 2000 bucks for a type R cangeover.
Cams cost 900 pistons cost 200 intake manifold costs 400 lsd w/ trans rebuild costs 1500
Now thats gonna cost over $3000 and not even everything i would want to do. So tell me how building my 85,000 mile engine is more worthwhile or even cheaper then doing what i said?
[Modified by gsr mike02, 4:39 PM 5/20/2002]
Old May 20, 2002 | 03:37 PM
t's Avatar
t
$4000 for a complete ITR motor with Tranny is a good deal, especially new
Dont forget the ITR ecu, exhaust manifolds are different lengths, intake piping is different, coolant hoses are different length and ABS has its own ecu and will not be affected.
Old May 20, 2002 | 04:39 PM
ITRmike98's Avatar
hmm one more question... Will a JDM ECU work in an american car or would i have to buy an american ITR ECU? Or, could i get the JDM ECU chipped to work with an american car?
Old May 20, 2002 | 04:52 PM
t's Avatar
t
JDM ecu will work, but there is a speed limiter in the JDM ecu (which can be taken out with certain fuel/VTEC controllers)
Old May 20, 2002 | 05:05 PM
B18 B e a s T's Avatar
Go for it man. Especially since you can sell your old motor and tranny.
gsrboost
Jun 22, 2006 10:41 AM
97pearlwhitegsr_canada
Apr 2, 2004 07:04 PM
IntegR97
Sep 7, 2003 02:58 AM
pzoltan67
Dec 16, 2001 11:10 AM
pzoltan67
Dec 13, 2001 11:03 PM
