HELP!!! Crank Bolt!
Old May 23, 2002 | 02:13 PM
cbmlsvteg's Avatar
Default HELP!!! Crank Bolt!
i'm attempting to change the timing belt on my girl's teg, but i can't get the $%^& crank bolt off. i've tried a long breaker bar w/ a pipe, and i've tried 3 impact wrenches (425-450 lbs of torque). Any tips!!? When looking at the bolt, i attempt to loosen it counterclockwise, same way the crank is suppose to turn. Am i doing this right? Because the %^&* bolt won't come loose. I knew it would be a pian to pull off, but i wasn't expecting it to be this hard with the proper tools....thanks in advance.
Old May 23, 2002 | 02:20 PM
Fooser's Avatar
Default Re: HELP!!! Crank Bolt! (cbmlsvteg)
I think you need a special tool to take it off. I remember in my helms manual looking it up and it looked like a bar the held the outside in place while you fit a ratched in there to loosen it.
Look it up and you will see. Let me know if you need the instructions cause I can probably look them up for you when I get home in like a hour from now.
Post quickly cause I'm gone in like 10 minutes.
Old May 23, 2002 | 02:23 PM
cbmlsvteg's Avatar
i gotta helms manual and all it says is to use a strap wrecnh to hold the pulley in place....i got one of those and it works to keep the crank from moving.....hmmm???
Old May 23, 2002 | 02:25 PM
Fooser's Avatar
I would think since it spins counter clockwise the way to get it off is clockwise right? Check rotation of the nut. I will find out for sure when I get home cause I helped a friend do this to his car and it didnt seem too hard. will get back to you.
[Modified by Fooser, 11:28 PM 5/23/2002]
Old May 23, 2002 | 02:27 PM
cbmlsvteg's Avatar
Default Re: HELP!!! Crank Bolt! (Fooser)
thats what i'm thinking.....because on my dad's mazda that's how it was......but i'm not sure on this...i always follow "righty tighty lefty loosy"
Old May 23, 2002 | 02:29 PM
Fooser's Avatar
ya after cranking 450 pounds I'm thinking you probably broke something. Thats way too much. Might be a little har to get off now. I'm thinking clockwise cause if it loosened counter clockwise wouldnt the force of the crank cause it to loosen?
Righty tight lefty loosey unless something is turning a certaing direction I believe.
[Modified by Fooser, 11:30 PM 5/23/2002]
Old May 23, 2002 | 02:32 PM
cbmlsvteg's Avatar
i dunno......i'm still a little skeptical......
Old May 23, 2002 | 02:37 PM
t's Avatar
t
Counter clockwise to come off.
Drive the car to a shop with air tools and a strong gun, have them shoot it off for you and than put it back on not as tight as before, than go home and continue on your timing belt change.
Old May 23, 2002 | 02:45 PM
cbmlsvteg's Avatar
Default Re: HELP!!! Crank Bolt! (t)
i gotta hook up at pep boyz...hopefully they can help..thanks
Old May 24, 2002 | 07:18 AM
Stewie's Avatar
There's a special tool that acura uses, I think it's called a hex or something. I used a chain wrench and I let the the lower conterl arm stop the wrench from turning as I broke the bolt loose.
Old May 24, 2002 | 07:37 AM
SPECR's Avatar
Default Re: HELP!!! Crank Bolt! (Mac8008)
It's called a harmonic balancer holder ... 50mm hex that attached to a breaker bar
http://buy.snapon.com/catalog/pro_de...re&dir=catalog
Old May 24, 2002 | 09:02 AM
ALF's Avatar
ALF
That's your best bet. Also, spray it down with some liquid-wrench or WD-40 before you go. Believe me, breaking that bolt spoils everything. Thankfully, I was lucky enough to take out the rest easily. All the Honda & Acura dealers I went to didn't carry any...only option was mail order (ie another week of downtime). Put a GOOD strong air gun to that bolt and it will come right off.
VTECVillain
Sep 1, 2023 06:49 PM
stackz
Jun 4, 2009 03:49 PM
shutta
Nov 13, 2005 02:34 PM
luti
28
Jan 9, 2005 01:05 PM
